Old 02-25-2010, 01:54 PM
Tobyw79 Tobyw79 is offline
Chevy shifting problems
I have a 1997 Chevy P/U that is giving the following codes: P0740, P0753, P0785, & P1860. The check engine light comes on intermittently, the gauges will temporarily quit working, and it feels like the transmission is stuck in 3rd gear when I take off. I have read a few other post that suggest the ignition switch needs to be replaced when all these codes appear. Is this a correct diagnoses?
Thanks,
Toby
Old 02-25-2010, 10:03 PM
777stickman 777stickman is offline
Re: Chevy shifting problems
Hi Toby and welcome to AF.
Yes the ign sw could be suspect, BUT before you go there try a couple of other things.
1. REPLACE the TRANS fuse (even if it looks good).
2. Remove the connector at the tranny. Clean with electrical cleaner and inspect the pins and sockets and then re-seat it.
3. When this happens just stop with the engine running and check for power at both sides of the TRANS fuse. If you do not have power there, then you can start suspecting the ign sw and/or wiring in the column.
Let us know what you find.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-02-2010, 09:53 PM
transman618 transman618 is offline
Thats a bad ignition switch. Very common problem in these.
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
