Old 02-25-2010, 02:21 AM
rollin80s rollin80s is offline
datto 510
well i dugg this revell kit i had started to hack over 5 years ago. the detail is ok, needs some work on cleaning up, the front wheels don't turn right or left, has poor fitment and mold flash just about everywhere even on the chrome pieces, and panel lines need attention as well. gotta fix some mistakes from years ago so it's scratch building time.
Old 02-25-2010, 12:30 PM
Viccario's Avatar
Viccario Viccario is offline
Re: datto 510
Nice, looks like a good kit. I like the moulded in arches and bonnet pins. Was it the Pete Brock race version originally? Wheels look good. It will be good to see progress so that I can compare to my four door version!
Old 02-26-2010, 02:47 AM
Re: datto 510
thanks bud. it's not the BRE version. it's the tuner. ill be replacing the hood and trunk pins with some PE pieces. i hope you enjoy it as much im enjoying your build.
had some time to work on it a bit. started cleaning the chassis a bit, and the main hoop for the roll cage. the stance and camber is what ill be going with. a bit extreme for some, but i like it.
Old 02-26-2010, 11:38 AM
Viccario's Avatar
Re: datto 510
Looking good! Wow that camber and stance are extreme indeed! I have seen some pictures on Japanese websites with that sort of stance and camber. I must admit it is a bit too extreme for me (looks a bit too much as if the car has been squashed by something very heavy to me) but as long as you like it that's what is important!
Old 03-04-2010, 04:40 AM
Re: datto 510
haha, yeah. i love the demon camber!
well, did a bit more tonight. didn't realize how long it takes to have to make your own parts.
here i am fixing the mistakes of the past. 0_o
couldn't get a good shot of the front
but i like this angle better
Old 03-20-2010, 02:48 AM
Re: datto 510
ok, so i haven't had much time to work on this. did some work tonight.
i thought of going this route. making some light housings.
BUT instead i thought of these when i busted out the techno TVR's
and this wing
and this seat as well. to give it a old school feel.
Old 03-20-2010, 04:03 AM
JDMaholic JDMaholic is offline
Re: datto 510
looking good man, i cant wait to see how the front end turns out
Old 04-01-2010, 12:15 AM
datto 510
this time around i took a look at the exhaust. i managed to bend it like so, enough to barely clear the chassis and axle.
and this was my alternative to making the wheels turn left/right and add some more "demon camber"
but after doing some more research, the control arms are in the wrong spot and it's missing the strut arms to keep the arms from moving while steering. being picky about this, i am going to correct this issue.
Old 04-01-2010, 08:09 PM
tonioseven's Avatar
Re: datto 510
Yeah man, knock it out of the park! I pulled my kit out last week to give it another look as well. That engine bay would look great stuffed with a rotary engine.
sam-r350 UP.Browser/6.2.3.8 (GUI) MMP/2.0
Old 04-02-2010, 02:48 AM
Re: datto 510
thanks bud, glad to see someone else bust out a 510. a rotary would look good under there, a triple rotor would be even better?? hmm
i have a buddy w/a 510 rotary powered little beast. wicked fast and handles like a go-kart.
Old 04-02-2010, 05:41 PM
CrewDawg15's Avatar
CrewDawg15 CrewDawg15 is offline
FuJimmy!!!!
Re: datto 510
Looks great so far Luis. So are you going all BOZOU with the pipes, or gonna cut them to stock length?
Old 04-02-2010, 06:33 PM
Re: datto 510
hey hey jimmy, it's up in the air on the length of the pipe, might do a dual tip afther the axle?? not full bozo, but some of everything i like. it's a surprise.
Old 04-23-2010, 02:50 AM
Re: datto 510
ok, so it's been a while since the last update. been fiddling with it every now and then.
heres some of what i've done lately
i reduced the inside lip, looks closer to the real thing
made some strut arms and brackets. might redo them.
stripped the chrome off the bumpers (further below) valve cover and carb set up. horrible looking carbs, i might use some fuJIMMY carbs
new dash. might put some carbon fiber on this panel. dunno.
engine bay is gonna be a partial front tube chassis.
drilled some holes on the rivets as if they are missing, along with the side marker lights and key hole. part of the theme.
Old 04-23-2010, 05:48 AM
Lownslow's Avatar
Lownslow Lownslow is offline
Re: datto 510
Niiiiiiiiiiiiiiiiiiiiiiiiiiiiceeeeeeeeeee
Old 04-29-2010, 03:40 AM
Re: datto 510
heres some more. im slow paced
did some engine work. got some hose fittings this weekend. got the right ones on a guess.
made the stock oil pan into a race style oil pan.
made these pulleys, didn't like the bulky, flash flooded parts.
started to fill in the frame/chassis rails, since they are not this way on 1:1
dual pipe??? or single??
enclosing the engine bay. don't mind the gap, it will not be there once properly fitted in the end.
thanks for looking.
