Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-25-2010, 02:08 AM
z3r0 z3r0 is offline
Proper Cleaning of Poppet Valves
Couldn't find the thread I was reading a little bit ago.
I have problems with my vehicle and people help me.
I'm trying to give back. You'll need some tools...
CPI INJECTOR CLEANING PROCEDURE
Part # and info
1050002 Top Engine Cleaner
12345104 Port Fuel Injector Cleaner
1. Loosen the fuel filler cap to relieve vapor pressure in the fuel tank.
2. Raise the vehicle on a hoist.
3. Locate the underbody fuel line junction point: l For S/T and L-van, it is along the left frame rail at approximately mid-vehicle. l For M-van, it is behind the left-front wheel housing.
4. Loosen and disconnect both the pressure and return lines at their junction points. The fittings towards
front of the vehicle (both pressure and return) have "male" fittings, and the fittings towards the rear of
vehicle have "female" fittings.
5. Install the J 44466-2 (this hose has two 90 degree male fittings and no service port) to the "fuel tank" side of the fuel pressure and return lines. Installation of this hose eliminates the need
electrically disable the fuel pump and allows fuel to recirculate to the fuel tank.
6. Install the J 44466-1 (this hose has two female fittings and a service port) to the "engine side" of the fuel pressure and return lines. Installation of this hose creates a "loop" through the hose and the engine side of the fuel system.
7. Obtain the J 35800-A . Make sure the valve at the bottom of the canister (3) is closed.
8. Remove the canister top and add 24 ml (0.8 fl. oz.) Top Engine Cleaner, GM P/N 1050002 (Canada P/N 992872), to the canister.
9. Fill the remainder of the canister with regular unleaded gasoline and install the canister top.
10. Suspend J 35800-A from a convenient location under the vehicle.
11. Connect the hose from J 35800-A to the service port on the J 44466-1.
12. Open the valve at the bottom of J 35800-A.
13. Connect a "shop air" source to the fitting at the top of J 35800-A and adjust the regulator (See Fig. 4 , Fig. 1 ) to 75 psi.
14. Lower the vehicle to a convenient height and start the vehicle. It may be necessary to re-adjust the J 35800-A pressure regulator to maintain 75 psi.
15. Let the vehicle run at idle until the canister is empty and the vehicle stalls.
16. Turn OFF the vehicle ignition switch. CAUTION: Considerable fuel leakage may occur. Make sure that protective eyewear is worn, and that suitable fuel containment measures are taken. WARNING: This cleaning procedure and service tools separate the fuel tank and pump from the cleaning process. Do not allow the Top Engine Cleaner solution to reach the fuel tank and/or pump. Top Engine Cleaner solution may cause a failure of the fuel pump.
17. Raise the vehicle.
18. Remove the shop air supply from J 35800-A.
19. Depressurize J 35800-A.
20. Disconnect J 35800-A from J 44466-1.
21. Remove J 44466-1 and J 44466-2 from the vehicle fuel lines.
22. Re-connect the vehicle fuel lines.
23. Lower the vehicle.
24. Add one (1) ounce of Port Fuel Injector Cleaner, GM P/N 12345104 (Canada GM P/N 10953467), to the vehicle's fuel tank for each gallon of gasoline estimated to be in the tank. Instruct the customer to add the remainder of the bottle of Port Fuel Injector Cleaner to the vehicle's fuel tank at the next fill-up.
25. Tighten the fuel tank filler cap.
26. Start the engine and check for fuel leaks.
27. Clear any Powertrain DTC codes as required.
I did not come up with this info. It is not my own. Information should be free.
Thank you
