Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-13-2003, 03:45 AM
grumpee grumpee is offline
Radiator Problem?
Hi all, i am new to this forum. My 94 Teg suddenly overheated last night. Both fans are not working and since i am no mechanic, i really have no ideal whether this is the problem or something more serious is causing this. Never got this problem before. Just wanted to know if the fans are both not working, would the engine overheat so quickly? I just changed the exhaust as well and there is a tiny bit of soot (brown?) coming out from there. Is this normal? THANKS ALL.:bandit:
Drive fast, die faster, so what? I Like....
Old 04-13-2003, 03:54 PM
york2600 york2600 is offline
Send a message via AIM to york2600
The soot is normal. It means your burning a bit rich. It's actually closer to a black color. I was burning really rich a while back. It's sad when u wash ur car and realize that the back bumper was a different color than you thought it was for the last few weeks. The radiator fan is probably the engagement switch. I don't know the exact name for it, but if you want to do the work yourself I can scan the page in the Helm's manual that describes it. It happened to my mom in her Civic. The switch should cause the fans to switch on when your stopped at intersections and stop and go traffic. Have that checked out, but you might want to check the coolant and oil levels too because you shouldn't immediatly overheat.
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
96 teg radiator replacement joshjohnson_79 Integra 0 10-24-2010 01:40 AM
Originally a Radiator Fan Problem, Now Car Won't Start fiskee '91 - '96 2 09-09-2009 12:17 PM
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
1990 Ford Econoline Van Radiator Problem, I think.. ariel418 Econoline 6 05-12-2009 06:40 PM
93 G20 Radiator problem aktano General 1 07-09-2001 04:08 PM
