99 Ram 1500 5.9 4X4 unable to shift into 4 wheel drive
I have a 1999 Dodge Ram Extended Cab 5.9L 4x4 with 66,000 miles and im having an issue with the 4 wheel drive transfer case. the Shifter linkage broke recently and had a shop put a new one in but now you literally have to use either a pry bar or punch and hammer to get the truck out of 4 wheel drive and back into 2 wheel drive. Fluid has been changed and no abnormal sounds coming from the transfer case. With the low miles and being 11 years old im believing that the 4x4 wasn't used too often and the internal shaft that does the selecting is seized or corroded . Is there a way without pulling the transfer case to free this up. Any information would be greatly appreciated. Thanks everyone.
Re: 99 Ram 1500 5.9 4X4 unable to shift into 4 wheel drive
I've had to back up a coupla car lengths to get mine to loosen up before.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" ![]() "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 ![]() Time to turn so's you don't burn.
Thanks Chris for the reply, lucky for me the dealer i bought the truck from is paying to have the transfer case pulled to have it repaired at no cost to me. I appreciate your info. and will most likely have many more questions later on.
