Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-23-2010, 07:28 AM
BUCHO_LE1 BUCHO_LE1 is offline
'02 Rodeo Headache
I can't seem to fix this problem with my '02 Rodeo. I have replaced the EGR valve, all four O2 sensors, fuel filter, and the MAF sensor but I still get a CEL light that illuminates and occasionally blinks. I also continuously get several codes every time I stop into Auto Zone. The codes are P0101 MAF sensor performance, P0401 EGR system fault, P0161 O2 Bank 2 heater condition, P0172 Air/Fuel ratio in only one bank, P0175 Rich/Lean condition Bank 2.
Please help!!!! I hate that my Rodeo is sick and I can't fix it!!!!!
Old 02-23-2010, 08:07 AM
XR400R XR400R is offline
Re: '02 Rodeo Headache
How does it run?
Does it surge at all; is the idle steady?
Has the intake manifold gasket been replaced ever/recently?
2001 Passport, 3.2L V6, 4X4, Auto, 130K mi., mostly stock
Old 02-23-2010, 08:15 AM
The idle is weird. It only idles funny when in park or neutral and that is not always happening. When I shift into drive or reverse it runs fine. Sometimes it runs perfectly fine and then other times it stalls completely when I shift it.
The intake manifold gasket has not been replaced yet. I am thinking that is what I am going to attempt next. Is there a place to find step by step instructions. I am a helicopter mechanic so the only engine I have worked on in depth is turbine engines.
Old 02-23-2010, 08:46 AM
I would agree with you, IMG replacement is the next step here.
There is some info out there (not a lot). Also, you need a service manual if you don't already have one. If you don't, let me know & I'll be glad to PM you with a link to a file sharing site where I put a manual for downloading at someone else's request.
As an aircraft mechanic, replacement of the IMG should be a relatively simple task. While you're in there, I would recommend you replace the thermostat if it has not been done. It is buried beneath the manifold & you basically waste the manifold gasket when you try to get to it. Now's a good time to do that. I recommend using only Isuzu-OEM thermostat. They seem to last a really long time (I replaced mine at 100K miles without failure).
Old 02-23-2010, 08:50 AM
amigo-2k amigo-2k is offline
Isuzu Guy
2x... I've had my IMG replaced 2x with the same issues you have.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-23-2010, 09:10 AM
Thanks. I do not have a repair manual so that would be great if you could send me any information on the replacement of the Intake manifold gasket or anything else for repairing my Rodeo.
I will replace the gasket tonight if I can figure it out and fill you in on the repair.
Thanks a lot!!!! I hope this works!
Old 02-23-2010, 09:31 AM
PM with link(s) sent.
Also, I have a short .pdf file that describes the process on a 2nd Rodeo (with pics) that may be of help. If you will PM me with an e-mail address, I will send it along.
Just a couple of tips from my experience:
Careful removing the fuel rail/injectors. They pull straight out (after removing the harness) but be ginger about it. It's easy to screw up the two O-rings on each injector. Best to replace them if you can, & put a bit of motor oil on them at reinstall to keep from damaging them on reinstall.
Also, have 4-5 cans of brake cleaner ready to clean inside of both halves of the IM. It will be totally black & brake cleaner does a better/quicker job than any thing else I've found.
One last tip, BE SURE & clean out that long, EGR transfer pipe running the length of the lower manifold section. It tends to get gummed/carboned up real quickly resulting in poor/no functioning of the EGR valve, resulting in bad knocking on reglar gas.
Best O luck.
