Old 02-23-2010, 12:16 AM
chevy9 chevy9 is offline
fuel pump
I have a 1990 chevy c1500 with a 5.7 lt. It started running like crap and the service engine light came on. The codes were lean exhaust, egr valve and o2 sensor. I have replaced egr valve and solenoid, o2 sensor and map sensor. None of which made a difference. Now my fuel pump is out. Could that have been the problem the hole time? It was missing when it accelarated but ran smooth when at a steady speed and idled up and down
Old 02-23-2010, 01:02 AM
consultIII consultIII is offline
Re: fuel pump
yep. sounds like fuel starved symptoms. check fuel pressure cranking if it doesn't start...sorry don't have spec's for you...will try to get some tomorrow.
Old 02-24-2010, 08:54 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: fuel pump
Like they say codes do not say replace parts but check it out first.
Low fuel pressure almost always throw a lean exhaust code.
What was the code no?
MT
Old 03-01-2010, 06:58 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Re: fuel pump
I had similar problem on my 98 Silverado. It would sputter and die, but only under a load - such as climbing a long hill. Otherwise, it ran great. The truck gave out all kinds of different codes, and the dealership was originally stumped. They replaced cap and rotor, then I did wires, fuel filter, etc, etc.
My problem turned out to be the fuel pump. I had the pump replaced by a local shop. But they used a local brand, not OEM. That pump lasted about 2 months, then same sputtering started again. This time, I had the shop use OEM fuel pump and now all is well.
So, I would suggest that you be sure you have a OEM pump in there.
Good luck.
1968 427 Camaro SS
1998 Silverado K1500
2004 Corvette Coupe
2011 Chevy Avalanche
______________________
Old 03-20-2010, 12:21 PM
gocougs gocougs is offline
Re: fuel pump
I have 98 K1500 that showed the same problems during acceleration. I found the problem to be a plugged fuel filter, which was starving the engine at the higher flow rates. My pump never quite but it did make a loud whining noise until I replaced the filter.
I have a friend with a 96 K1500 that has gone through a couple fuel pumps. His factory pump quit after 160K and he replaced it with an aftermarket pump. That one quit after a few thousand miles. He's back to an OEM pump.
Old 03-21-2010, 09:04 AM
j cAT j cAT is offline
Re: fuel pump
the reason there are many with these fuel pump problems are because GM does not give a replacement interval....most with few problems replace the filter at 30,ooo mi...the next reason is because of constantly running with low fuel ,,at / below 1/4 tank....This damages the pump with overheating ...with low fuel in the tank more crap enters the pump and plugs up filter etc....
with a good fuel pump, a restiction like a filter dirty will make the pump louder ..
whenever the pump is replaced replace the fuel pump relay ..A bad pump can damage the relay contacts !
