Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 02-22-2010, 07:09 PM
Mattman78765 Mattman78765 is offline
Exclamation 1990 beretta gt 3.1L transmission question!!!
the car goes through all 3 gears, but at 55mph the RPMS are high. like there is no cruising gear. what is the problem? and the transmission fluid smells burnt.
Old 02-25-2010, 08:57 PM
rhandwor rhandwor is offline
Re: 1990 beretta gt 3.1L transmission question!!!
I would get three estimates at transmission shops for repairs.
Old 03-03-2010, 05:39 AM
jsgold jsgold is offline
Just a shot in the dark....if you have just purchased the car etc. maybe check to see if previous owner had unplugged the TCC solenoid, which would explain the car running at a bit higher rpms...When the TCC goes bad the car will stall in low gear so people unplug them, but engine will run higher rpms than before. If this has just started then yes, get it to a shop for a checkup.
I used to be indecisive, now I am not so sure.
Old 03-04-2010, 06:13 AM
Anthony123456 Anthony123456 is offline
sounds good to me
test king|ccent practice exam|ccia
Old 09-30-2010, 11:47 PM
Newyorkberetta Newyorkberetta is offline
If you are in need of a working transmission for your beretta let me know
I have one in a parts car in your area
Thankls
Old 10-20-2010, 10:55 PM
Hers some additional parts available in Queens New York
Zipo code 11368
Great dash door pane;ls interior sheetmetal etc etc etc!Private owner!
