Trans shifting late
What would cause the trans to shift late under low throttle on a 98 transport. It shifts like it would if you were accelerating fast. It lets the engine wind out before shifting. It doesn't shift unusually hard just late.
Re: Trans shifting late
Mileage? The tranny fluid level is where it's supposed to be? What color is it? Not knowing your expertise, I have to ask if you followed the correct procedure stamped on the dipstick? When was the last tranny fluid and filter replaced?
The problem with doing nothing is not knowing when you're finished. |
Millage: 170,000
Fluid level is correct Fluid and filter were changed about 1,000 miles ago when I felt it was starting to shift late but it wasn't as bad as it is now. When I changed the fluid it was dark compared to the new fluid but there were no shavings in the pan. The fluid and filter were changed previously at around 100,000. |
The vacuum modulator is connected to the engine vacuum manifold to rapidly respond to changes in engine loading, and has an important effect on shift quality.
It's located on the radiator side of the tranny. (4T60-E transaxles) There may well be another component causing the fault but I'm afraid that's out of my depth. Hopefully a quaified tech will see your problem and can help.
Have you tried different places for different opinions during test drives?
