Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 02-22-2010, 01:35 PM
kwik12 kwik12 is offline
Corolla - The Weirdest Starting Problem
Hey guys nice forum!
Anyway, I got a 1990 Toyota Corolla (manual/standard) and it runs fantastic. The only thing is I got one small problem.
-->When my car sits for about six or more hours it takes a while to start up (meaning it will start up... but it will make that starting sound for 10-15 seconds then slowly start to burp and then start).... once it is warm though (say I drive it for five minutes, go to the store come out) it will start normally.
Any ideas?
(I dont think it's the starter, and it may be a fuel check or something)
ALSO : I've tried keeping the key in the on position before actually starting the car for about 20 seconds
Old 02-22-2010, 03:03 PM
fix_her_myself fix_her_myself is offline
Re: Corolla - The Weirdest Starting Problem
Any ideas?
Most likely its a vacuum problem. Most engine problems that occur only at a low temperature will be a vacuum issue. Start with the EGR, see if there is any air flow around the base which would indicate gasket leak. Loosen it up see if the problem is worse or the same.
Is your check engine light on? You may want to get the codes off the computer, they may indicate what system is faulty.
Old 02-22-2010, 03:11 PM
Scrapper Scrapper is offline
AF Premium User
i would say starter if it cools off then starts? could be coil also or out of time. but if i had to guess it's the starter.
Old 02-22-2010, 09:14 PM
hey guys,
thanks for the reply. If the problem still occurs I'll message you.
Old 02-24-2010, 08:59 AM
Yes most times when the starter is going out its hard to start when hot, thats why I believe vacuum since he is saying its starting fine hot but slow cranking when cold. Normally it if is also running chopy cold its 90% of the time a vacuum or emmisions problem.
Old 02-24-2010, 07:49 PM
yeah its only screwing up when its cold
Old 03-02-2010, 03:19 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Your car may have what is called a "cold-start injector" which feeds fuel into the intake when you try to start. If it is clogged or stuck closed, you will have difficulty starting until enough fuel is fed by the normal injectors to start it.
Also, check the fuel pressure. If it is lower than normal, then again it will take longer for enough fuel to be fed into the intake to start. A clogged fuel filter or worn out fuel pressure regulator is usually the culprit...worst case could be failing fuel pump.
Good luck and Welcome to AF!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 03-02-2010, 04:40 PM
thanks... I'm gonna try what you suggested. Well see what happens.
Also,
my car is QUIET!!! Like, when its running normally (been driven for a while type of thing, its warm...) and I come to a stop... my car is fairly quiet.
Is this a good thing?
Old 03-03-2010, 09:56 AM
jdmccright's Avatar
The RustBuster
A smooth idle is good.
If those check out okay, then have what are called the IAC and EGR valves checked. If those aren't clean or don't open and close properly then they can cause hard starting.
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 03-03-2010, 12:43 PM
Also,
That should be a good thing, however I would short the terminal to read the codes. If its not EGR which is the most common issue for cold running issues, and if you don't have a cold injector issue. You may read an O2 sensor fault which may point to a clogged catalytic convertor. I do not recommend knocking it out, get a replacement because once you knock those out it won't run right.
I still think its your vaccum, most likely your EGR valve is stuck or the gasket is leaking. You can pull off the EGR and I think that year you can feel the valve.. you should be able to move it by hand if you cannot replace it. Get a new gasket for good measure its worth the buck or two.
Old 04-29-2010, 12:54 AM
famlycar famlycar is offline
I sure would like to know if your problem was solved and what it was kwik12...?
Anyway, I had a similar problem with my 96 corolla and it turned out to be some loose screws on the starter solenoid. That was in the summer last year and I haven't had any problems since. I clean my battery real good during each oil change which helps also.
Old 10-04-2010, 02:11 PM
Going to fix the problem today... well let you know!~
