Old 02-22-2010, 08:34 AM
sppedley sppedley is offline
Programming my key fob
I have a 2004 Chevy Trailblazer LS.
Can anyone help me program my keyless entry remote?
Thank You!!
Old 02-22-2010, 06:27 PM
heck524 heck524 is offline
Re: Programming my key fob
Just Google "programing gm key fob"
just pick one of the sites
Old 02-24-2010, 03:51 PM
94Z28Conv.'s Avatar
94Z28Conv. 94Z28Conv. is offline
Send a message via Yahoo to 94Z28Conv.
1. Close all doors
2. Insert key into ignition
3. Hold down the power UNLOCK button on the driver's door panel, continue to hold down
until instructed to release in step 9.
4. Perform steps 5 through 8 in a fairly rapid succession.
5. Turn the ignition to the ON position (as far as you can go without starting the engine.)
6. Turn the ignition to the OFF position.
7. Turn the ignition to the ON position (as far as you can go without starting the engine.)
8. Turn the ignition to the OFF position.
9. Release the power UNLOCK button on the door panel. The vehicle should respond by
door locks locking and unlocking automatically. (If locks do not cycle after you let go,
not before you let go of the unlock button, then the vehicle has not entered programming
mode and you must start procedure over. Remove key from ignition, open drivers door
and return to step 1 ).
If the locks do cycle automatically then proceed to step 10.
10. Hold down the LOCK and UNLOCK buttons on the remote until the doors lock and
unlock. This may take up to 30 seconds.
11. Repeat step 10 NOW for each additional remote. (Including any existing remotes).
12. Turn the ignition to the ON position to exit the programming mode.
13. Test remote(s).
Old 03-19-2010, 10:01 PM
CraigZerch CraigZerch is offline
i have found www.programyourremote.com to be a good source for programing most remotes. It will also tell you if it has to be done by the dealer.
Old 03-21-2010, 10:56 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
No dealer needed.
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
