Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 02-21-2010, 10:59 PM
burly94gt burly94gt is offline
Why so cold??
My 1994gt runs colder than normal. I installed a Griffin Racing aluminum radiator and 180* thermo., and many many more mods when rebuilt. Also it has tremec 3550 5spd tranny. I bought a thermo. radiator cap, and it consistantly reads a fluid temp. of 105-110*. Is this bad?? (as in damage to the motor) Ive never had the issue of my car running TOO cold. Seems kinda strange to me. also has egr and emmision pump delete
thanks for any and all feedback
God said RWD, and all the little torque lovers of the world said, AMEN!!
Old 02-22-2010, 12:49 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Why so cold??
It is not good. The engine will remain in open loop mode running rich. It may be a faulty t-stat. Remove it, and test it in a pot of water on the stove. Have a thermometer to see the temp of the water. A 180* t-stat should start opening at 175 and be fully open at 200 if I remember correctly. If it's opening correctly, then test/replace the ECT sensor. I believe your year would have two. One is used for the PCM and one is for the dashboard gauge. Try swapping the connectors and see if the other one shows the same temperature.
My 180* t-stat runs the engine at 187-189* year round.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 02-23-2010, 02:03 AM
Re: Why so cold??
Awesome thanks man. ill check the thermo tomorrow. The car is def. running rich. I can smell the gas in the exhaust fumes... Also, im not sure if this is a symptom of the same problem, but when i first start my car in the morning or when the motor sits for long enough to cool the engine sputters at 4-500 rpm. i have to hold the pedal down so the car will idle correctly until the engine warms up. Once warm, the engine idle pans out to around 850rpm. Sometimes while driving ill take the car out of gear, and the rpms drop so far the car stalls.
Old 02-23-2010, 12:46 PM
Re: Why so cold??
Your second issue sounds like a bad IAC valve. Sometimes you can remedy these by removing them and cleaning the ports with carb cleaner. I did with mine but it helped for only about a month. Ended up replacing it with a Duralast replacement from Autozone for $80 and no problems since.
The IAC valve is located on the back of the intake plenum. It is held on my two 10mm bolts. Just remove the plastic intake tube to it, remove the 2 bolts, and pull off. Be careful not to damage or remove the paper gasket and be sure to put it back in place afterwards or else it will cause a vacuum leak.
Old 03-26-2010, 04:06 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Why so cold??
Blue,
Do you know at what temp it stops the open loop? I thought it was like 210*?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 03-26-2010, 06:57 PM
Re: Why so cold??
It's definitely not as high as 210F. I believe it is somewhere around 150F but not sure exactly.
Old 03-26-2010, 09:02 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Why so cold??
It's always been my belief that 180* stats are still too cold for these motors. I always run the factory 195* stat to keep the engine at the correct operating temperature for optimal performance which was calibrated by Ford in the ECU.
The engine temperature triggers Open and Closed loop operation of the EEC. Closed loop will only happen if the engine is fully warmed up and operating somewhat normally. If something is really out of wack then it will stay in open loop, such as low coolant temp. Open Loop is meant to be operational at 2 points, WOT and before the car warms up. At open loop fuel enrichment occurs which could reduce mpg.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 03-27-2010, 07:51 AM
SkylineUSA's Avatar
Re: Why so cold??
Looks like 140*.
Good read.
http://www.veryuseful.com/mustang/te...InnerWorkings/
Old 03-27-2010, 10:20 AM
SkylineUSA's Avatar
Re: Why so cold??
I mentioned 210*, because I read that many moons ago on the Corral, a lot of bad info out there. A lot like higher octane for a stock engine
