Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-21-2010, 09:26 PM
03 Dodge Ram 1500 03 Dodge Ram 1500 is offline
Trouble shoot a engine code
I have a 2003 Dodge Ram 1500 4.7
The code is PO440
I have been told it the gas cap. I just want make sure that is the problem. I already fix the canister tank one of the hose was cracked.
Please help!!! Just want to know if I'm doing the right thing.....
Old 02-22-2010, 12:25 AM
hundahunta hundahunta is offline
Re: Trouble shoot a engine code
evap purge system performance......there can be many problems.....bad purge, open wire in the ldp switch, no vacuum at the ldp, etcccc....but I have replaced many of leak detection pumps to fix this problem...faulty switch inside of the pump...
Old 02-22-2010, 09:11 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Here's an interesting thread,
http://www.automotiveforums.com/vbul...ighlight=p0440
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
