Old 02-21-2010, 07:42 PM
lexbagley lexbagley is offline
4-wheel drive issue
2004 2500 hd duramax. Only 1 front wheel will pull, front right. What are the most likely issues.
thanks
Old 02-21-2010, 07:58 PM
j cAT j cAT is offline
Re: 4-wheel drive issue
thanks
usually this will be the locking actuator motor / circuit is defective...check for voltage at motor then check that the motor is not open/shorted/ fuses etc...this is the front diff actuator..as this locks the front axles together..
the transfercase encoder motor locks all front / rear diff's together ...
Old 02-21-2010, 08:48 PM
If the actuator is faulty, would the front right engage and not the left front side?
Old 02-21-2010, 08:54 PM
like I stated the front diff locking actuator locks the front axles together ..thats all it does..it has nothing to do with 4wd..it lockes the left front to the right front..when it works !
Old 02-21-2010, 09:18 PM
When the 4 hi is pressed, I can hear and feel the actuator engaging. The 4 hi light will stay on. I will change fluid tomorrow and see what happens.
Old 02-21-2010, 09:21 PM
why change fluid ? why are you ignoring my testing suggestions..
do you own a volt ohm meter or know how to use it ?
Old 02-21-2010, 09:36 PM
Fluid is dark gray, changed probable 60K ago. Voltage was 12.3. Actuator sounds and feels normal as pushrod moves to function properly.
Old 02-21-2010, 10:16 PM
if this is the case then the front dif must need to be replaced...
do you operate this in any 4wd position on dry solid pavement..
remember this is only part time 4wd..this is not to be used on solid dry pavement at any time...in any 4wd position..another item that damages the front diff fast is different sized/worn tires tires used with different wear destroys the diff's and stresses out the drive train..
tire rotation is required with these vehicles...
Old 02-24-2010, 09:47 PM
Streetwise's Avatar
Streetwise Streetwise is offline
Send a message via Yahoo to Streetwise
If you change the tire size, will this cause an issue? I went with a bigger tire all around.
Old 02-25-2010, 09:05 AM
all the tires must be the same size and worn the same..larger/smaller tires wont hurt because they are all the same ...
Old 02-25-2010, 12:52 PM
iroc343 iroc343 is offline
How are you determining that the front right is the only one pulling? With an open differential, front or rear, the wheel with the least traction is the only one that will spin under normal circumstances. Most people don't realize that four wheel drive only means that one wheel one each axle has to turn, unless the vehicle has locking / limited slip type differentials.
Old 02-25-2010, 02:00 PM
In any 4wd position on these vehicles the locking actuator locks the front axle together as one....thats what it does ! if not locked there is a problem in the front diff....or the locking actuator is not working....
the rear diff is open until a slip is generated then that too locks so with this vehicle in 4wd on a snow / ice road all wheels will be locked into each other in a true 4wd....
