Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-21-2010, 07:47 PM
hinton08 hinton08 is offline
Firefighter317
Exclamation 91 k2500! No start! Help!
1991 GMC K2500 5.7L V8 MANUAL TRANSMISSION. Recently it has been having trouble starting. When you go to start it, its like the clutch is not being pressed down. It will not even turn over at all. Has a new battery in it. Figured the starter was bad since the cluth pedal start switch has been replaced not too long ago. BUT I would like to know how to test the clutch pedal start switch just in case before I buy one. I hooked it up to my scanner but theres no info on the switch being open/closed so I need info on how to test the switch before I remove the starter. Thanks!
Old 02-21-2010, 07:48 PM
Firefighter317
Exclamation Re: 91 k2500! No start! Help!
Forgot to write on here that you CAN roll start the truck and it will start fine. Wont start using the key and trying to crank it, but if you roll start the truck on a hill, it starts fine. Not sure if that will narrow it down?
Old 04-12-2010, 10:02 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Try by passing the clutch start switch with a jumper wire. If that doesn't work look at the ignition switch.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
