Old 02-21-2010, 04:49 PM
piersm2 piersm2 is offline
Audiobahn A2300HCX - Need Help!
I have a Audiobahn A2300HCX that does not work. It just seemed to quit putting sound to the subs. The blue status light is on and the fans work, but the dials indicating the output read zero. I took the amp apart and cleaned as much as I could. After putting it back together and in my car, the same problem arises. Does anyone know of anything else I can try to fix this problem?
Old 02-21-2010, 06:46 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Audiobahn A2300HCX - Need Help!
are you sure the power wire is good, fuse not blown ? Also check the gnd wire, make sure it is solidly attached to the car chassis. Are the subs good ? A shorted sub could trip the protection circuitry.
Old 02-21-2010, 06:51 PM
I have a circuit breaker installed for a inline fuse. I would assume that they are good since the fans still run. I had the amp hooked up to a 15 and it does the same thing.
Old 02-23-2010, 07:07 PM
Audio Guy
unfortunately, it sounds like the amp is fried
