Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-21-2010, 02:46 PM
toddmpa toddmpa is offline
rear wiper self starts on key-on and key-off
On an '01 rodeo LS 3.2. It swipes for a minute or two and then stops. It stops on the detent after key on but in mid-stroke after key-off. I pulled the fuse. Still turns itself on, although the dash switch stops working. Showed up initially when I turned off the wiper using the switch but the wiper kept going. Relay issue?
Old 02-22-2010, 06:22 AM
XR400R XR400R is offline
Re: rear wiper self starts on key-on and key-off
Sure sounds like it. A $12 fix if you will tackle it yourself, $300 fix if you take it to a shop (if you can find one who can work on it).
I replaced two relays on my wiper controller board in about 1.5 hrs. It's a PIA, but not too difficult.
Is a very extensively discussed issue. See topic 60 here for excellent guidance:
http://isuzufaq.ibctech.ca/
2001 Passport, 3.2L V6, 4X4, Auto, 130K mi., mostly stock
Tags
rear , switches , wiper
