Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-21-2010, 08:22 AM
bigwheelz1728 bigwheelz1728 is offline
97 Burb No power steering
Just wondering what else I could easily check before replacing my power steering pump. Was going down the road and poof no power steering. Ive replaced a few power steering pumps in my day and never had one go without a) locking up or b)making some type of noise letting me know its getting worn out. This one did not do any of these things just all of the sudden no power steering. Any help would be appreciated thanks
1997 Chevy Suburban K1500 5.7 V8
Old 02-21-2010, 08:52 AM
j cAT j cAT is offline
Re: 97 Burb No power steering
take the belt off the pump and see if the pulley pulls out .
some of these pumps the shafts break ...
Old 02-21-2010, 09:50 AM
Shaft is broke off! Just it is the pump thanks guys
Old 02-21-2010, 05:39 PM
I SEEN THIS BEFORE ! I looked at the metal and something didn't look right ...So I did an internet search , took a bit to find the answer..seems that GM contracted to have these parts made by some company..they used scrap steel...
Old 02-22-2010, 04:40 PM
Will308 Will308 is offline
I've got a '97 GMC Suburban and figure it's pretty much the same as yours. 177,700 miles and I just did the replacement of the old PS unit and found there's a kit to replace the silly electronic sensor that makes the power steering feel tighter at highway speeds.
It's just a bypass pipe. I'd recommend replacing that sensor while you have it apart. We tried desperately to get the old sensor to index correctly with the new pump, no matter how we screwed it in it would always be in a position that would not allow the pump to mount correctly . It kept hitting the motor mount. I ended up having to replace it. Kit was like $ 70.00 from the dealer.
Hope this helps.
Old 02-23-2010, 07:57 PM
Elbert Elbert is offline
assume the belt is still good?
You make no mention of any noises or unusual events, other than all of a sudden no PS.
Elbert Clarke
Old 02-24-2010, 08:25 AM
this poster has resolved his issue with the sudden loss of the power steering .. the pump shaft snaped ..
Old 02-24-2010, 10:56 PM
ok...I missed the obvioius.
Elbert Clarke
