Old 02-21-2010, 05:35 AM
mikeso_81 mikeso_81 is offline
2001 Grand Prix Control Arm Installation
Hi,
Does anyone have step by step instructions (Pictures and what type of tools would be nice) on how to install control arms on a 2001 Pontiac Grand Prix GT?
Thanks
Old 02-23-2010, 04:13 PM
andretti andretti is offline
Re: 2001 Grand Prix Control Arm Installation
Front arms I'm guessing?
1) Raise and support, remove tire
2) Disconnect ABS sensor connector and harness clip
3) Remove sway bar link
3) Remove ball joint cotter pin, loosen stud nut
4) Separate ball joint from steering knuckle
(either hammer loose or BJ separator)
5) Remove arm to sub-frame bolts & arm
The Following User Says Thank You to andretti For This Useful Post:
rlh95 (10-04-2011)
Old 02-23-2010, 06:07 PM
These are excellent visuals. Would you be able to tell me where you located these from? I bought a Haynes repair manual which was not helpful.
Thank you.
Old 02-23-2010, 06:36 PM
I have access to several online databases. Also there are many DVD sets available, Google "Autocd".
If your only problem is the forward vertical bushings (VERY COMMON) they can be replaced without buying a new arm.
Old 02-23-2010, 10:18 PM
My front two bushings are bad (both sides) so I thought it would be easier to replace the whole control arm. I was reading that you need a special tool to install the front control arm bushings. The kit comes with both the front and back bushings along with ball joint so I thought it would be easier (but little more expensive) repair.
Old 10-04-2011, 04:53 PM
rlh95 rlh95 is offline
Need to know all i can find out about changing both lower cont arm&outer tie rod ends & hub assem for 2001 pont grand prix
