Go Back   Automotive Forums Car Chat > Cars/Parts for Sale/Exchange
Cars/Parts for Sale/Exchange Sell your car and parts or post what you are looking for.
Old 02-21-2010, 02:31 AM
mute mute is offline
Drifting.com Project RB25DET 240sx For Sale : So-Cal
If you're local to Southern California I'm in process of getting ready to sell the Drifting.com RB25DET Project drift car with standard RB25DET swap.
(Possibly selling an additional built longblock later - 12k OBO for that (comes with some obligatory strings though, email me if interested))
Car is an engine bay cleanup and big brake kit away from a photo spread in Import Tuner or Super Street.
CONTACT: ALI
[email protected] ONLY I barely check in on forums.
Car located in Southern California.
Car available to be seen on Thursday/Friday nights only.
Wanted : 18k OBO (don't bother posting or emailing unless you are a serious buyer)
Check it out:
Parts Included:
Suspension:
-Megan Racing Track Series Coilovers
-MR Rear Upper Control Arms
-MR Rear Lower Toe Arms
-MR Rear Lower Traction Rods
-MR Rack Ends
-MR Tie Rod Ends
-MR Front Pillow Tension Rods
-MR Aluminum Subframe Bushing Kit
Cage:
-L-CON Racecar Fabrications:
Custom 8pt SCCA spec Roll Cage
(tightest tolerances you will ever see)
Interior:
-SPARCO Pro-2000 seat (driver)
-SPARCO EVO seat (passenger)
-SPARCO 6 pt. Harness
-SPARCO 4 pt. Harness
-SPARCO 325 Deep Dish Steering Wheel
-Yashio Factory Pink Shift Knob
-Yashio Factory Pink Ebrake Release knob
-Yashio Factory Carbon Fiber Style Shift Boot with Pink Stitching
Exterior:
- URAS Front Bumper
- GP-Sports Side skirts
- GP sports Rear Bumper
- Front and Rear Wide Fenders (20 in front, 40 in rear)
- Seibon Carbon Fiber Hood
- JDM Corner Lights
- 180sx Tail Lights
- 180sx Rear quarter panel windows
- 4 - 17” Falken Hanabi Rims
- 4 - Falken Azenis 615 rubber (Brand New)
Transmission:
-RB25 Mission (needs new shift fork)
-SPEC Stage 3 Clutch
-Steel Braided Slave Cylinder Line - Sr20store.com
-The Driveshaft Shop 1 Piece Driveshaft
-Kaaz 2way LSD (installed by Kaaz for Drifting.com LSD install DVD)
Motor:
- R33 RB25DET Motor from R33 Front Clip (installed by Marco from SR20 Store and Gary from Project Car magazine and owner of Syko Performance for Drifting.com motor swap DVD)
- Syko Performance RB25 Converted Upper/Lower Harness
- Syko Performance Motor Conversion Mounts
- Syko Performance Transmission Brackets
- Syko Performance Sway Bar Brackets
- Syko Performance Intercooler Piping
- Large Intercooler Core - Meganracing.com
-Couplers And Clamps - Hosetechniques.com
-Power Steering Cooler - Sr20store.com
-Greddy RB25 Intake Manifold
-Gizzmo Thermal Intake Gasket Included
-Infiniti Q45 Throttle Body
-Apex-i Power Intake
-Flex-A-Lite Dual Radiator Fans
-Braille Auto Carbon Fiber Battery
-STOCK S14 Radiator
-Z32 Fuel Filter
-Twin Turbo Supra Fuel Pump
-S14 Throttle Cable
-5Zigen Exhause System
-Rev On Valve Cover
Electronics:
-A’pexi RB25 Power FC and (limited ed. gold D1 Apexi FC Commander)
-A’pexi AVC-R Boost Controller
-A’pexi DECS EL II Carbon Fiber (limited) Tachometer
-A’pexi EL II Series Guages (Boost, Oil temp/psi, Water temp, Fuel psi)
-A’pexi Auto-Timer
Bad:
-Transmission has an issue, diagnosed as broken shift fork, does not shift smoothly. I hear it's a relatively cheap fix.
-Cracked driver side rear view mirror
-Cluster set up could be redone
-Power Steering leak from somewhere at the rack to hose connection.
Bonus for buyers at 18k price:
500+ HP axles
Braille Battery Charger
If you have any questions as to how the car was put together you can buy the swap video from Drifting.com that documents each step. Also you can find my videos under "Drift Garage 1" on Youtube to see the installation of all the Apexi electronic components.
