Old 02-20-2010, 02:37 PM
901epd 901epd is offline
no power
starts fine. but has no power. I have to play with throttle to get to speed. Help?
Old 02-20-2010, 03:43 PM
Mickey#1 Mickey#1 is offline
Re: no power.
What year/model?
How old is the cat?
How many miles since the plugs, wires, air & gas filters were changed?
See if it runs better with the MAF sensor unplugged.
Check fuel pressure.
Check Throttle Position Sensor.
Old 02-20-2010, 03:49 PM
Re: no power. rest of info..
Vehicle is a 2002 pontiac, Grand Prix, small engine, with 171,000 km(104,00miles). Just tried new fuel filter with no success. Tune-up done at 70,000km... Code reads ;P0404. Runs nice otherwise. Can barely do 60kms/hr
1. I was thinking of straight pipe instead of the cat. Isn't the oxygen sensor ahead of the cat? So it should be uneffected?
Last edited by 901epd; 02-20-2010 at 04:04 PM. Reason: reading other comments, it's looking like plugged cat.
Old 02-20-2010, 04:22 PM
Re: no power.
P0404 is a code for the EGR valve. I don't have any experience with that code so I'm not going to be able to help.
Old 02-21-2010, 06:43 AM
BNaylor's Avatar
BNaylor BNaylor is offline
By small engine do you mean the 3.1L V6?
It sounds like a bad CAT converter. See link below. This notice covers 2001-2002 GM cars with the 3800 V6 engine but still applicable to GPs with the 3.1L V6. Check with GM of Canada and see if they will cover it under emissions warranty. If you run a straight pipe in lieu of the converter you will get codes like P0420 and a SES/CEL light unless a 02 simulator is used (post CAT) or PCM reprogrammed to preclude any converter efficiency tests. Plus it may be illegal.
Click here
A bad CAT could affect the EGR system or even evaporative emissions system when certain tests are called on since the engine vacuum is affected or used so start there first. On the P0404 DTC the EGR pintle position error is too large when the test is run. (>15%). It could be an EGR valve electrical or mechanical issue.
Timeslip 08/12/06
AF Community Guidelines
