Old 02-20-2010, 11:04 AM
klutz_100's Avatar
Source for rubber-backed metal sheets for photo etching?
Is anyone aware of a source for rubber-backed sheets that can be used for DIY photo-etching?
Old 02-21-2010, 05:57 AM
das_auto's Avatar
das_auto das_auto is offline
Re: Source for rubber-backed metal sheets for photo etching?
Not sure about this, but send a PM to Gio (gionc) he seems to know his way around PE manufacturing. Maybe he has a tip for you.
HTH!
Emil
Old 02-22-2010, 06:30 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Gio recommended SAEMANN Ätztechnik
saemann-aetztechnik [at] t-online.de
Old 02-22-2010, 07:05 AM
klutz_100's Avatar
Thanks Alex.
I have that strore already from Jaykay's WIP but apart from the fact I don't speak a word of German, even after browsing and using babel fish, I don't think they have any.
Google has turned up absolutely nothing for me on this so I am beginning to wonder if rubber-backing is not an in-house part of the chemical milling process...?
Old 02-22-2010, 08:05 AM
ales's Avatar
Forza Schumacher
Sorry, I didn't notice that you were looking for rubber-backed ones, thought you menat the ones that have the photoresist on them. My bad, but good luck and do let us know if you manage to find a source for these materials.
By the way, I did not have much trouble communicating with the Saemann guy in English.
Old 02-22-2010, 09:14 AM
ariel's Avatar
ariel ariel is offline
Hello
I have had photo-etch produced with the rubber backing. If I am not mistaken it is applied during the process. But to make sure 100% contact this company they did the rubber backed etch for me.
http://www.imei.net/
HUMAN IS TO ER
www.pacms.org
http://www.mamasboyz.org/
Old 02-22-2010, 09:26 AM
godfather23's Avatar
godfather23 godfather23 is offline
Originally Posted by klutz_100 View Post
Thanks Alex.
Buddy, if German is in need, I´m your man!
Robert
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 02-23-2010, 02:30 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Steve: Mr. Saemann spell a good english , may be a bit "sharpen" and less fluent than your
I think you'll just etch a normal plate from one only side, keeping the red adesive foil in the other. I see MFH do so. I done experiments at my PE adventure begin: it come out just great, I got a sheet of nuts and roundels that sleep after years on its red foil.
Only thing is that you can't achieve an "engraved" effect, I tried using gray levels on the film but I didn't improoved the system to an acceptable level.
gio
Old 02-23-2010, 11:06 AM
klutz_100's Avatar
Thanks
I will give that a try
Old 02-23-2010, 11:42 AM
Ettore Ettore is offline
Klutz, Go to a hardware store and ask them for the liquid rubber that is used to dip tool handles in. It comes two ways: in a can that you can brush on to the metal or as a spraycan. Spraycan is easier, use two coats. Works great. I've gotten it at Ace Hardware, Lowes and Home Depot. Ettore
Old 02-23-2010, 11:46 AM
klutz_100's Avatar
VERY interesting. Thanks!
Any chance you could post a photo of the spray-can? Please
Old 02-23-2010, 11:52 AM
I looked to see if I had a can to tell you who makes the stuff but don't have any. After opening, it drys up in a month or two, no matter how air tight I make the top seal. You wouldn't have any problem finding it. Ettore Proud member of ACME
Old 02-23-2010, 11:55 AM
ZoomZoomMX-5's Avatar
Would that be the rubber stuff like you use to dip tool handles into for a better grip? Something like Plastidip?
My Fotki Album
Old 02-24-2010, 12:33 AM
CFarias's Avatar
CFarias CFarias is offline
As mentioned above the rubber coating for tools is what I use and it works great. Use the spray and at least two medium to light coats.
Using the rubber backing lets you do photo-etch without any frets and metal parts will come off easily with a bit of acetone.
Be sure your metal is clean before you spray.
Old 02-24-2010, 01:51 AM
gionc's Avatar
Authorized Vendor
I don't understand the difference between a rubber film or the adesive red backing film that the pre-sensitive plates has: does this meant that you Steve are doing experiment with Positiv20 laquer?
I never got decent results with it so I'm quite interested to see other's experiences.
It may have incredible developments on the "chemical milling" way on 3D objects: imagine a brass cylinder with radial engravings, ex. a 1/24 alternator; obviously it would need a special UV source all around....
gio
