Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 02-20-2010, 02:02 AM
jonathandavis04 jonathandavis04 is offline
94 na upgrade
Hi , I really need help with my Z(94 na 2 seater).I'm definetly going to convert to TT so since I'm going to TT(around 550hp) I'd like to know what parts that can go on the conversion I can use on my na now without affecting it. I'd appreciate your help correcting and guiding me.
INJECTORS-Can I put 370cc on my na or higher like 555cc.In case that I can what would I need ?.
ECU-Do I just upgrade to TT specs?
ALTERNATOR -they are interchangeable , but has anyone try it?
FUEL PUMP-can i put a TT pump on my na?
INTAKE-can i put a JWT dual pop intake or is just not possible?
JDM High Flow Fuel Filter -?
EXHAUST -can i put a TT on my na?
Sard Fuel Pressure Regulator - Type R (Race) - 300ZX - ?
Fuel pump unit?
I know I'm missing some so if you can please where or what is wrong and the consequences and give some ideas I'd really appreciate it ,thanks a lot
Old 02-20-2010, 08:57 AM
Andrewhuffman Andrewhuffman is offline
Re: 94 na upgrade
NO!
If you cange injectors, you will need a tune.
but why install them on an na, they serve no purpose.
NO!
You will need a tune, or a TT wireing harness with stock everything.
if your goal is 550, a tune is a must.
The alternators swap, but no point, the NA will work fine.
... NO!
Nissan fuel filter
WHY? they are the same from the x back.
you will need down pipes and test pipes.
... just no
Fuel pump unit?
no, the na fuel pump controller will work.
but the tt fuel pump will be a must.
for 550, you will need
forged internals
600r or 675 turbo kit.
down pipes
huge intercoolers
bigger than 555cc injectors
tune
stage 5 clutch
a ton of shit.
it will be absolutely stupid to try and make your na 550, or add turbo shit later just to swap it back to the tt motor.
if your serious, get a short block and build it from the ground up and expect to spend at least $10k
GT2560r's, Nismo 615cc, ARP Head Studs, UD Pulley, SouthBend Stage5 clutch, 60mm TB's, Ash-spec Tune, Specialty Z 3" DPs, HKS intake,
Energy Suspension, z1 Drive Shaft,E-fan, Port/Polished heads, AMS Manifolds, HKS SSQV BOVs, Howe Radiator, RPS segmented LW flywheel, UR OverDrive waterpump pulley, Billion Thermo, z1 silicone hoses, Stillen gauge pod w/autometers, D&S rotors all around
Old 02-20-2010, 09:31 AM
Re: 94 na upgrade
thanks for your help , , my point is not to make my 550hp now , for that i'm going to get a front clip later , just want to know what parts necessary on a tt swap i could use on my na now, i always heard that ecu + intake + exhaust would give a little more power , about the exhaust just wanted to know if i can get an aftermaket one like the borla , intake-can i put the dual pop? , and why i can't upgrade to TT specs on my na , whats the problem with that and with the fuel filter and fuel pressure ? thanks for your help ,
Old 02-21-2010, 07:30 PM
Re: 94 na upgrade
its completely different.
Im not going to explain it in every detail, you can search for previous information posted. its everywhere.
