Old 02-19-2010, 09:48 PM
DANZIGS DANZIGS is offline
No headlights
I have a 00 grand caravan and my lowbeams stopped working. I have parking lamp function and brights. I replace the headlight switch and that did nothing to help. I notice that when I turn the park lamps on, I hear the relay clicking and they light up along with brights when activated. When I put it to the low beam position(headlights on position), I do not hear the relay clicking from the relay and fuse center under the hood like the other lights. I tested the bulbs against the battery and the low beams are good on the bulbs them self. Any help would be great. Could this be a problem in the relay box or the BCM?
Old 02-20-2010, 07:09 PM
tempfixit tempfixit is offline
Re: No headlights
Have you tryed a different relay. Has the multifunctional switch been tested??? Does it have DRL's?
Old 02-21-2010, 07:11 AM
Re: No headlights
No daytime running lights and yes I've tryed different relays. Can it be something inside of the relay center that can be corroded?
Re: No headlights
I also replaced the headlight switch.
Old 02-23-2010, 05:52 PM
Re: No headlights
Turned out to be the BCM
