Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-19-2010, 03:01 AM
kellen128 kellen128 is offline
Burning Oil
I have been noticing for a while now that my car is burning a lot of oil. I have a 2.0L non-turbo auto.(girls old car...couldn't get a diff. one) As long as she had it, and now it will burn through about 5qts in 2.5 months. When I start the car is when the most amount of smoke is seen, but it will smoke while driving. Lately its begun to sputter when I take off from a stand still. The sputter feels like either a bad misfire, or the engine is hungry for fuel. The only add-on I've made is an intake. I'm trying to get an idea of what would be the best route to figuring out/fixing the problems, and if its even worth it to do the repairs.
Thanks for any help/tips.
Old 02-19-2010, 08:18 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Burning Oil
Welcome to AF.
You should probably think about doing a compression test on it so you can see what kind of condition the motor is in. Smoke at start up sounds like valve stem seals but 5 quarts in 2.5 months is a lot of oil. Does it have any leaks or just burning all of it? It may be time for a rebuild. The studdering could be caused by a few things, I would check the plugs on it first, since its burning oil its probably fauling those out quickly.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
