Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 02-18-2010, 11:04 PM
shark7000's Avatar
shark7000 shark7000 is offline
bleeding fuel lines? 87 Supra, non-turbo
I just did all the gaskets on this engine, including the fuel injectors. Now I don't know the proper procedure to bleed the air out of the fuel lines. I tries to start then quits. Most other cars have a bleeder valve like a tire valve. I can't find it in the book, and I'm having a hard time getting it done.
I would appreciate any help.
Thank you,
Mark
Old 02-22-2010, 04:47 PM
barnhill19 barnhill19 is offline
Re: bleeding fuel lines? 87 Supra, non-turbo
i have a 88 toyota supra that wont start i am woundering if any one know if it would be the distributor or the computer i have no fire and its a non turbo 7mge if u can help please
Old 02-22-2010, 06:53 PM
shark7000's Avatar
I believe I was able to bleed the fuel lines now. But it starts and then shuts off after about 2 seconds. I did the jumper on the troubleshooter connector to turn on the fuel pump to stay on, and it still shuts off. As I keep trying to start it, it runs really rough for a second and dies. Is there an electrical sending unit that might cause this?
Old 02-24-2010, 02:27 AM
shark7000's Avatar
I just found out today that my problem was a wire connector just past the air filter. I forgot to plug it in. You might want to check to make sure everything is still plugged in on your car. Other than that, from what I have been reading in the repair manual, you may need to be checking all your ignition electrical like plugs, wires, distributor, coil, and igniter.
