Old 02-18-2010, 09:15 PM
mhowe1182 mhowe1182 is offline
loud knocking need help!
got 99 k1500 and theres a loud knocking high up on engine but dont know what it is hoping it not as bad as i think can anyone help?
1999 k1500 350 hd tranny
8 inch lift
35" tires
Old 02-18-2010, 10:20 PM
Re: loud knocking need help!
ok little more info when the truck is running and i give it gas from on throttle at the intake and i can feel the knocking through the top and it get louder when i give it gas but the knocking isn't at the same rpm as the rev. oh and you can hear it better on the driver side. so any help would be good. thanks!
350 5.7 vt
8 inch lift
35" tires
Old 02-19-2010, 08:27 AM
j cAT j cAT is offline
350 5.7 vt
remove the valve cover inspect when engine is running..could be a broken spring or rocker bolts
Old 02-19-2010, 10:18 AM
k thank give it a try let you know if thats what it is
8 inch lift
35" tires
Old 02-19-2010, 05:44 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
or a collapsed lifter. Run your truck with the valve cover off and at idle, touch the top of each rocker. You should be able to find the knock.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-19-2010, 06:56 PM
thanks give it a try.
8 inch lift
35" tires
