Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 02-18-2010, 01:40 PM
someret someret is offline
Unhappy Looking for FSM '96 Town Car
Need help removing anti-theft system. I think its causing a short in the horn. The horn needs to work so that it can pass inspection. The problem started when the alarm went off in the middle of the nite for no reason. We had to disconnect the battery to disable it. If anyone has a FSM this would be extremely helpful as "haynes" just does not provide enough info.
Old 02-18-2010, 05:37 PM
All2kool's Avatar
All2kool All2kool is offline
Re: Looking for FSM '96 Town Car
You could just hard wire the horn and add a button near the dash - it'll get you through inspection anyway and I don't believe your horn has to work via the steering wheel; I could be wrong.
When I worked at Hertz in the 80's we had several Ford model cars (Tempo & Topaz for two) where the horn button was actually on the Turn Signal stalk. Stupid yes, but it was factory.
Old 02-18-2010, 09:04 PM
Towncar's Avatar
Towncar Towncar is offline
... The problem started when the alarm went off in the middle of the nite for no reason. We had to disconnect the battery to disable it. If anyone has a FSM this would be extremely helpful as "haynes" just does not provide enough info.
First.. it's VERY possible both your horns are just plain dead, test them to be sure, and while your at it, test the voltage at the horn with someone pressing the button.
I do have your 96 FSM for download (198mb zip), PM me. <edit> I sent you a PM !
PS: Alarm going off unexpectedly is 99% of the time attributed to the latch switches. First suspect is the hood switch (mine was cured here), then the side doors, and I've also heard one lever in the trunk pulldown assembly caused the problem.
-Steven
1996 Town Car, Cartier
