Old 02-18-2010, 12:43 PM
GTPjoe GTPjoe is offline
Question zzp catless downpipe??
Hello i was wondering if the zzp catless downpipe was universal for all the l67 supercharched engines in different makes,(gtp,ssei) I found one on craigslist for 60 dollars and want to kno it fits my gtp before i purchase,the add simply states l67 supercharged zzp catless down pipe for $60 any help would be greatle appreciated as i would like to purchase if this will fit my car thanks!!
Old 02-18-2010, 04:13 PM
GTP Version 2.0 GTP Version 2.0 is offline
Re: zzp catless downpipe??
I don't believe it will fit a Bonneville. The interlock flex section is at a different location. I would only recommend a catless down pipe for race applications. You won't be able to pass emissions unless you change some codes. You will need an O2 sim or PCM programming to remove the 137-141 & 420 codes. They are not legal for use on public roads. I've been hearing that new emission laws will soon go into effect where if you have any check engine light (emission related or not) you won't pass emissions. $60 isn't bad, but a new zzp downpipe with cat is around $160. If you go with the craigslist offroad down pipe you will have to get your PCM reprogrammed ($100+ if you can't do it yourself) or a o2 simulator for around $80 if you can still find one.
