Old 02-18-2010, 11:45 AM
Roadrider1 Roadrider1 is offline
Question 1995 S-10 Blazer starting problems.
Hello.
I have a 1995 S-10 Blazer.
It will start correctly about 95% of the time.
However, every once in a while, it will start, and instantly cough itself out.
After it does this, i try to crank it again, and it does the same thing.
Always on the third time, it will not even start. It will just crank, crank, and crank.
Although, After i disconnect the pos. battery cable, and re-connect it for about ten seconds, it will start just fine until it does it again.
What's strange? No check engine light.
What could this be?
Thank you.
Old 02-18-2010, 01:40 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1995 S-10 Blazer starting problems.
What engine?
Any codes?
How is the tune up end?
Mileage since last tune up?
How is the fuel pressure when no start?
Is it losing spark when no start?
MT
Old 02-18-2010, 02:45 PM
Originally Posted by MT-2500 View Post
What engine?
Any codes?
4.3 Vortec
No codes at all.
Tune up end?
And it just had the engine completely cleaned, re-built and installed about 5k miles ago. It's been doing it almost since it was re-built.
Fuel pressure = 62 psi.
Haven't checked the spark.
Old 02-18-2010, 03:06 PM
MT-2500's Avatar
AF - Advisor
Originally Posted by Roadrider1 View Post
4.3 Vortec
No codes at all.
Tune up end?
When no start check for lose of spark to plugs and lose of cranking fuel pressure.
MT
