Go Back   Automotive Forums Car Chat > Cars/Parts for Sale/Exchange > Parts for Sale
Old 02-17-2010, 06:29 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Three sets of Ecotec fuel injectors
For sale are three sets of fuel injectors from an '04 Cavalier. They fit all Cavalier/Sunfire gasoline engines from '03-'05. They will also fit '02 Ecotecs, but are shorter and will require the spacer that is used with the '03-'05, this spacer IS NOT included. I assume that these injectors can also be used with all 2.2L Ecotecs, but it is your responsibility to confirm compatibility for your engine! I will leave this post up for at least two weeks, after that I'm listing any un-sold sets on E-bay. At the end of this time, the highest reasonable offer gets them, and I will change this post to read only "SOLD", so if you are reading this these injectors are still for sale. Please do not PM me with offers, post your offer here so everyone can see it. These sets are sold separately, so please include the set number(s) in your offer. These are only available as sets of four (4), I will not separate them.
Sets 1&3 include used o-rings, you should consider buying new o-rings.
Set #1: Stock fuel injectors. GM part number 12571863. All injectors are good, I replaced them when I added a supercharger to my car which required larger injectors. This set has roughly 75k miles on them, I always used good fuel and used BG fuel injector cleaner regularly. GM list price is $802.28 for the new/updated part number 12574335.
Set #2: GM Performance Parts number 12593904. These are the higher flow injectors that come with the GMPP supercharger kit. This set also includes the metal clips that hold the injector to the fuel rail. This set is new/unused and in the original boxes. I added a smaller pulley when I installed the supercharger and wasn't able to use this set. GM list price is $307.20
Set #3: GM part number 12790827. These are the green top LSJ injectors, they flow 36 Lb/hr. This set was only used for roughly 4k miles, but the bright green was hard to clean up and they look pretty dirty. This injector is slightly shorter than the other injectors and requires that you adjust the existing fuel injector spacer slightly, but they work just fine even with 14 PSI of boost trying to push them out. GM list price is 284.44
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
