Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 02-17-2010, 05:30 PM
loki_grins loki_grins is offline
95 dakota 4x4 stalling when stopping
My 95 Dakota has started stalling when I come to a stop
when I slow down for stop sign or red light after engine warms up
the RPM drop to very low and the oil gage drops , if I don't double foot the gas and brake to keep the rpms up the engine will stall
Friend said perhaps tork converter .
any help appreciated
Old 02-17-2010, 09:48 PM
troy1 troy1 is offline
AF -Advisor
Re: 95 dakota 4x4 stalling when stopping
Torque converter clutch would be more like a manual transmission that you don't push the clutch in "chug chug chug" when you stopped. Could be the IAC motor
Old 02-19-2010, 05:46 AM
gjwickline gjwickline is offline
try cleaning the throttle body. they get dirty, a heavy black residue build up. remove air cleaner assy. use a toothbrush and a good carburator cleaner and remove all the black residue from bores in throttle body and the butterflys. it will be a little difficult to start first time, hold pedal to floor and crank. this should help alot
Old 02-22-2010, 02:40 AM
zzGUY46 zzGUY46 is offline
Check your battery. Your idle control needs steady 12 volts. Had it happen with 3 different Dodges.
Old 02-26-2010, 09:54 AM
jayson454 jayson454 is offline
i agree with this post if you remove your throttle body and look into it you should be able to see light around the trottle blades if not clean both throttle bore and idle air controll bore it is black thing on the back of the throttle body now ill explain what is happening when you let off the gas the carbon around the throttle blades shuts off all air before the idle air controll can catch up
