Old 02-17-2010, 12:21 AM
xkoolrod xkoolrod is offline
Smile Reprogramming Keyless Remote
Bought a 95 Taurus without a remote so I needed to replace it. Now I Need programming instructions. If anyone can tell me how to do it or point me in the right direction, I would greatly appreciate it.
Thanks
Old 02-17-2010, 06:38 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Reprogramming Keyless Remote
Welcome to the forum!
If you have the owner's manual, the programming steps are outlined in the manual. If you do not have the owner's manual, the steps have been posted on this forum before. Try the "Search this forum" feature from the Taurus forum main page.
For future reference, you should always start with a forum search prior to starting a new thread. Chances are quite good that the topic has been addressed on this forum before.
-Rod
Old 02-19-2010, 04:23 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
These instructions will work on Taurus models, 93 - 95:
Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located in LR quarter panel area. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
