Old 04-12-2003, 07:31 PM
toontowncivic's Avatar
toontowncivic toontowncivic is offline
So here is the kit
Well half of it. I didn't get the side skirts to fit but here is the front and the fuggered back. The front has a warp as you can see. Then there is the nice mesh that the manufacturer painted blue. and the exhaust that didn't fit so the shop cut the bumper and bent the mesh.(which I will replace soon) Then there are just some other pics. Sorry about the wait on the pics i was in BC for a week.
STOLEN!
Old 04-12-2003, 07:51 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
I had that same bumper
This is the real melt pizzle
Old 04-12-2003, 08:14 PM
joeyo joeyo is offline
Send a message via ICQ to joeyo Send a message via MSN to joeyo
i love the blue accents on the interior. What kind of paint did you use for it?
Joey.
Old 04-12-2003, 08:33 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
damn man it looks clean as hell, not too bad at all ... so whatever happened with your shit getting stolen a while ago?
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
I bought the momo steering wheel and then took it to a shop and they matched the paint to the center of the wheel. It is special paint for vinyl and plastic!
STOLEN!
Old 04-12-2003, 08:35 PM
Thanks for reminding me! j/k The insurance company is backed up for inspections so i have to wait forever to get my car in there. I probably won't get shit since I don't have reciepts for my stereo. oh well. I am just trying to get over all of the Cd's and clothes that were stolen that they won't replace.
STOLEN!
Old 04-12-2003, 08:36 PM
care to share the make/brand of the paint? I'd love to do little accents like that but in red on my civic
Old 04-12-2003, 08:38 PM
I don't have a clue what the brand was. I just took it in and asked if they could match it. Try supply shops for automotive paint.
STOLEN!
Old 04-12-2003, 08:42 PM
oh okay i thought you did the blue paint on the vents etc.
i took my wiper blades off the car today and sanded them and painted them black. They were originally black but were all faded to shit. They look good I'll take a pic or two tomorrow.
Melt's Avatar
just make some reciepts ... oh well, I guess you win some you lose some.
Is your front emblem shaved? Looks tight.
AF Bay Area Crew
Old 04-12-2003, 08:53 PM
I did do the vents and all that myself. I just got the paint from them.
STOLEN!
Old 04-12-2003, 08:54 PM
ah okay
Old 04-12-2003, 08:56 PM
yeah I did it al before I got the kit on so they could fill the holes and paint the hood and back piece (where the emblems were). I thought about making reciepts but it is so sketchy doing that. They are really cracking down on insurance fraud here.
STOLEN!
Old 04-13-2003, 01:57 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
PAINTING INTERIOR PIECES:
Here's the exact process that I used, and my interior came out looking proffessional. Hope it helps.
Materials/Tools required:
-- Primer.
-- Krylon Interior/Exterior paint
-- Clear Enamel
-- 320 grit sand-paper
-- Rubbing alcohol and Q-tips and/or cotton balls
-- Masking tape (also good to have masking tape with attached drop-cloth)
-- Various sockets/screw-drivers, etc. for removing pieces
A few words about technique/safety:
-- When spraying your primer, paint, or clear-coat, be sure to keep the tip of your finger out of the spray. Having your finger in the way will cause paint mist to build up on your fingertip, and the airflow will blow the built-up paint off your finger in the form of little droplets of paint. If these drops land on the piece you're working on, you might as well start over, cuz they look like crap. The same thing happens if you use a plastic pistol-grip attachment on your spray cans.
-- I can't say enough how important patience is. If you rush, you are going to make mistakes, and if you don't fix the mistakes (which is a huge hassle), you'll have a horrible looking interior. So it's best to just do it right the first time. Do whatever you can to avoid over-spraying the pieces. Personally, I smoked A LOT of cigarettes and drank A LOT of beer between applications, just to keep myself from using too much paint all at once.
-- I made the mistake of painting all my trim outside on my back deck. For some reason, bugs were really attracted to my paint and clear-coat, and kept landing on the pieces. They'd get stuck in the wet paint, and some of them are still visible in the finished pieces. If you have access to a well ventilated garage or paint-booth, I would highly recommend using it.
-- If you follow these steps, you'll end up with a durable, professional looking painted interior.
-- If you plan on painting your entire dash, or your gauge cluster cover, a really light color like white or bright yellow, be aware that on sunny days, it will be reflected onto your windshield, and in my opinion is a bit distracting, and can make it difficult to see sometimes.
-- Always spray paint in a well ventilated area.
-- This process is only meant to be used on plastic pieces. I have no experience painting vinyl-covered surfaces.
The Process:
Remove each piece that you want to paint (consult manual if unsure how to remove pieces).
Use the following process on each piece you want to paint:
-- Wash with soapy water to remove built-up dirt and grease.
-- Sand each surface you wish to paint with 320 grit sandpaper.
-- Swab each piece with rubbing alcohol to remove any left-over Armoral, finger grease, etc.
-- Wash again with soapy water to remove rubbing alcohol residue.
* at this point, be sure hold the pieces by the edges, or by surfaces that won't be visible. This is to avoid getting greasy finger-prints on the prepped surfaces.
-- Mask off any areas that you do not want to get paint on.
-- Apply 2 coats of primer. I used Rustoleum Primer.
* When I refer to "coats" I actually mean LOTS of really light applications of primer/paint. remember to take your time, spray a little bit, give it a few minutes, spray again, etc. Do whatever you have to in order to avoid soaking the pieces. You'll just get runs and sags like crazy.
-- Primer dries pretty quickly.
-- Once each coat dries, it's a good idea to lightly sand the primer with 320 grit paper. And sand after the 2nd coat as well.
-- After sanding each time, wash the piece again with soapy water to remove sanding dust.
-- Apply 3-4 coats of paint. I used Krylon Interior/Exterior paint from the local parts supply chain.
* Again, remember to take your time applying the paint. The Krylon takes a lot longer to dry than the primer does, so give it a bunch more time.
-- Once the paint has completely dried (I would give it at least 24 hours to be on the safe side), apply 2-3 coats of clear enamel. I used Rustoleum Crystal Clear Enamel for this.
* Same process as with the primer and paint steps.
-- Let the pieces dry again for at least 24 hours before handling. It's the most frustrating thing to spend all this time and energy on painting the pieces, only to put a fingerprint in them or scratch them with a screw-driver trying to install them while they're still a little soft. BE PATIENT!
Old 04-14-2003, 10:02 AM
That's a good how to ci5ic. Wanna make me a how to on how NOT to get screwed on my bodykit?
STOLEN!
Car going to the shop..heres the mod list Eclipsewhipping 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 24 08-13-2006 02:16 AM
lets here the girls sideof the story AkaChevyMan Stress Release 11 11-12-2005 08:20 PM
Heres the RX-7 from HOT METAL.. josedi Car Modeling 3 09-30-2001 11:37 PM
So heres the plan zykotik General 12 08-31-2001 09:42 PM
Heres the Initial D webring...Alot of bad azz sites.. josedi Initial D 1 07-12-2001 11:27 AM
