| Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models |
need help replacing ignition switch
i am not very good with some things but i am pretty sure i can do this but i need these instructions simplified for me
1. Step 1 Disconnect the negative battery cable from the terminal on the battery. Remove the upper and lower steering column covers by unscrewing or unclipping them. (wat is the covers on the steering wheel or on the the part behind the steering wheel?) 2. Step 2 Remove the steering wheel by lifting off the center cover, disconnecting the horn wire and removing the retaining nut and washer. Make a mark on the steering wheel spline and the wheel itself so you can line it back up precisely. Pull the steering wheel straight back to remove from the shaft. 3. Step 3 Take off windshield wiper and turn signal switches by pulling them off as you did the steering wheel and disconnect the wiring. Slide the spacer sleeve off of the steering column. 4. Step 4 Unscrew the ignition switch mounting screws. Pull out the ignition switch. Disconnect the wiring connector from back of the ignition switch. Simply loosen the tabs and pull it out. 5. Step 5 Insert your key into the ignition. Turn the ignition switch to the locked position. Depress the retaining pin with a small screwdriver and turn the key to the Off position to free the cylinder. Once it is free, turn the key to lock position and remove the key and key cylinder. 6. Step 6 Install your old key cylinder into the new ignition switch assembly. Make sure the contacts in the cylinder and assembly line up. Reattach wiring to ignition switch, slide it into place, screw in mounting screws and reassemble steering wheel and switches. SOS I NEED HELP BEFORE I LOOSE MY JOB |
Re: need help replacing ignition switch
Check the how to at autozone.com, repair guides, register and go to steering, I believe.
