Old 02-16-2010, 07:28 PM
natesevern natesevern is offline
04 6.0L powerstroke egr delete kit
I have an 04 F250 with a 6.0L powerstroke and I'm having problems with the egr valve. So I've been looking into egr delete kits and talked to several Ford mechanics to see if they know anything about them. Obviously they don't or at least won't admit it. But one of them said the egr acted as the waste gate for the turbo and didn't know how the turbo would work without the egr. So my question is are there any down falls to deleting the egr?
Old 02-16-2010, 11:41 PM
RahX RahX is offline
Re: 04 6.0L powerstroke egr delete kit
An EGR really helps keep the exhaust temps down. Without an EGR your truck could damage the turbo and anything else in the exhaust.
Old 02-17-2010, 12:59 PM
dfordski's Avatar
dfordski dfordski is offline
Error code scans.
"Saving the World......One Ford Truck at a Time!"
Old 02-17-2010, 09:58 PM
the egr people say it lowers the engine temps and stuff though?
Old 02-18-2010, 05:53 PM
big white bufflo big white bufflo is offline
with the egr delet kit you drop ex temp by letting the exhust flow faster look on the ford powerstroke forum to get more info its a real good web for ford deisle people
Old 02-18-2010, 10:36 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
EGR block off is money well spent, Mines blocked off and so is everyone I touch on a day-to-day basis.
Let me ask you this: Do you have coolant coming from under the cap on the De-Gas bottle?
BTW: Most 03-04 6L wont throw a check engine light for no EGR valve.. 05-up will
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 02-19-2010, 12:35 AM
After poking around and reading about it, I have to say, I've changed my mind. On a diesel the EGR acts more like a crap in your mouth. Unburnt soot goes right back into the intake which gets into the oil. Makes it dirtier quicker and sorta kills your gas mileage and power to an extent. Buffalo isn't correct about it letting the exhaust flow free-er, EGR only recirculates it by way of an attached pipe which doesn't inhibit flow. Having to cool the exhaust going back into the engine seems to be a bit inefficient as well as the extra heat from the exhaust going back into the engine. Eliminating that cycle drops the temps and uncorks the power loss which also helps fuel mileage. I'd say go for it, even if it sets a light.
Old 02-22-2010, 10:46 AM
ken_man_1 ken_man_1 is offline
Common problem damn 6.o's. 05 will set a light when it's deleted, but what happens if it's still plugged in, but not in the engine? Think the light will still set?
Old 02-23-2010, 09:53 PM
ok sry it took so long to reply been busy plowing snow...anyway to answer the question no i don't believe so and i had ford look at it and they reprogrammed the computer and it seems to have fixed it and they said it needs a new thermostat which is an easy fix...I'm gonna plan on getting an egr delete from sinister this summer when i have extra cash, they have a warranty on theirs which is the only one i found that does. just a side note I've been told by many 6.0 owners that they have to have theirs reprogrammed a lot so that's something to look out for. they also said that putting chips in vehicles isn't so great cause the computer aren't designed to handle the extreme ones.
Old 02-23-2010, 09:57 PM
they say that if u leave it plugged in it wont set a light. they also recommend an chip or something like that, that will shut off the light. best thing to do is to talk to the people your thinking of buying one from, they'll know what their product does and doesn't do.
Old 02-26-2010, 07:47 AM
Sinister is a nice kit, We make our own, all CNC billet aluminium. Private message me if your interested.
And 03-04 will not set MIL (unplugged or removed)
05-07 WILL (unplugged or removed)
'95 Ford F-150
Ford Racing Pride
General Motors who?
Old 02-26-2010, 08:35 AM
danielsatur danielsatur is offline
Use gasket material to make your own EGR gasket, but don't make hole for Egr gases to pass.
Old 02-27-2010, 12:29 AM
The best material to use is the leaded material. Its gray/silver and shiny. That stuff will seal just about no matter what.
