Old 02-16-2010, 10:06 AM
chatty chatty is offline
serpentine belt replaced still not running
buick 97 lesabre My serpentine belt flew off. I towed my car back home. replaced the belt. still wont run. no spark?
Old 02-16-2010, 02:45 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: serpentine belt replaced still not running
Did the belt fragment when it came apart? If so, some of the metal strands may have damaged the crank position sensor, associated wiring, or reluctor ring behind the harmonic balancer. Recently, I had a customer with a 95 PA Ultra that did the same thing, in addition to the balancer & CKPS, it wrapped metal strands around the power steering pump drive shaft, and took out the front seal. We had to replace the balancer, CKPS and power steering pump.
Old 02-16-2010, 08:48 PM
Yep it fragmented alright. Sooo, looks like I will have to have it towed to a service station. Unless perhaps you could tell me how to check the crank position sensor? You happened to be my only reply but yet I think you got it. thanks so much.
Old 02-16-2010, 09:05 PM
HotZ28's Avatar
AF Moderator Elite
You can feel behind the balancer to see if you have belt windings in the backside of the balancer, but that will not tell the whole story! You will need to remove the balancer for inspection. BTW, are all idler pulleys in good shape? Normally, worn bearings in the pulleys will cause the belt to go off track and disintegrate.
Old 02-20-2010, 10:08 AM
Robdaparamedic Robdaparamedic is offline
If you are at all mechanically inclined, you can get at the sensor rather easily. There is only a couple 10 or 8mm screws holding it on and a plug. Look around each of the pulleys and shafts and clean them off. It may be time consuming but much cheaper than paying a shop. Good Luck.
Rob
Old 02-20-2010, 10:13 AM
maxwedge maxwedge is offline
A990 racer
Not true, the balancer must be removed to replace the cps.
Old 02-20-2010, 08:58 PM
RT Jam RT Jam is offline
Well I do think it's time to replace my belt. Thanks.
65 Plymouth Belvedere
69 Dodge Super Bee
87 Dodge Ram
93 Ford Mustang 5L
00 Buick Park Avenue
Old 02-21-2010, 04:17 PM
Smith1000 Smith1000 is offline
When this happened on my wife's '97 Lesabre, the idler pulley had frozen up, which burned up the belt. She kept going and ran a bunch of errands with no belt on it. Got home and said there was a light on on the dash. We got lucky though and it would still start and ran fine. Had to replace the pulley and the belt.
