Old 02-16-2010, 06:06 AM
hinton08 hinton08 is offline
Firefighter317
Exclamation 96 1500 Z71! Leaf Spring Swap?
Someone told me that you could take the leaf springs off a 3/4 ton and it will bolt right up to a 1/2 ton? Is that true and would you recommend it?
Old 02-16-2010, 09:07 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 96 1500 Z71! Leaf Spring Swap?
All depends on why you want to swap them?
Is you old one bad?
Do you want a good ride or to carry more weight?
MT
Old 02-16-2010, 09:56 AM
Firefighter317
No the old ones aint necessarily bad. I just heard it would make the back end squat less when you haul stuff? Will it make a rough ride or something?
Old 02-16-2010, 10:07 AM
MT-2500's Avatar
AF - Advisor
Heaver springs will carry more load but give a rougher ride.
A lot of people just use over load springs if hauling heaver loads.
How often and how much load/weight do you plan on hauling?
MT
Old 02-16-2010, 11:09 AM
Firefighter317
several thousand lbs of tobacco every year and then random stuff in between tobacco loads?
Old 02-16-2010, 11:48 AM
MT-2500's Avatar
AF - Advisor
If your springs that is on there is good.
And.
If not over a ton a good set of over load springs ratted at a ton should do it.
Also make sure your tires will carry the extra weight.
Also some people use good air shocks for extra weight.
And some just add a extra leaf to there old springs.
If you do go 3/4 heavy springs or extra leaf you will have a rougher ride when empty.
Good Luck
MT
Old 03-12-2010, 09:32 PM
mybad_z71 mybad_z71 is offline
i just went to the junkyard and while my rear end was being rebuilt, i put them on, assembled the whole thing couple of days ago, it rasied the rear end another 2 inches, my stock springs had 3 springs and 1 bottom bar, the 3/4 tons had 5 springs and a bottom bar, i like it.
