Old 02-15-2010, 09:53 AM
coletrain47 coletrain47 is offline
Re: 2000 blazer little or no heat
I have a 2000 Blazer and a few weeks ago I was getting a terrible smell and my window were fogging up. I just spent the last two days replacing my heater core, which was definitely the problem (the old heater core was leaking badly).
Now I am still not getting adequate heat and the windows still fog up, although not quite as bad as before. The engine takes a while to warm up, giving me luke warm heat inside the cabin. Then, the heat goes ice cold, and the engine temp spikes to 230 degrees.
I checked the hoses going into the (new)heater core, and one seems to be a bit cooler than the other.
I am thinking of doing a coolant flush, then changing my thermostat. Any comments or suggestions would be great.
Old 02-15-2010, 03:37 PM
old_master's Avatar
Advisor/Moderator
If the heater case is not cleaned out when you replace the heater core, (mop up the old coolant) you'll still have the smell and still get the film on the windshield. Eventually it will go away, but it'll take some time. A new thermostat and "burp" the cooling system will take care of the temp spike. Most likely has an air bubble in the cooling system. When the air is burped out, both heater hoses should be close to the same temp, (too hot to hold with bare hands for more than a few seconds).
You have to know how it works,
to figure out why it doesn't.
Old 02-15-2010, 09:38 PM
jyount jyount is offline
I recall when I worked at the dealer it was more than common for the s series rigs to have blend door problems because the vacuum solenoid on the tcase would leak transmission oil into the vacuum system, the heater controls were the first to go usually.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
