Old 04-12-2003, 05:10 PM
Barbie760 Barbie760 is offline
Post ABS light on
I have been having my ABS light coming on for the past few weeks. Today it came on and stayed on. My speedometer stopped working and I can only drive in second gear. Anyone have any suggestions?
Old 04-12-2003, 11:16 PM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
My guess is you have a problem with the vehicle speed sensor or it's wiring. The Service Engine Soon light should be on also.
You lost your speedometer which means the IP isn't seeing the signal from the PCM. Your ABS light is on probably due to the fact the PCM isn't receiving the signal from the VSS to send to the IPC or the ABS unit. And lastly since the PCM isn;t seeing the signal it went into default or "safe" mode and wont let the trans shift preventing further damage. It has no idea if you are doing 10 mph or 100 mph so it defaults to second or third gear.
I hope I didnt confuse you but it's probably just a simple repair.
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 04-13-2003, 09:00 AM
Schematic
Shop Foreman
Corvette Specialist
L1 Certified
Old 04-13-2003, 09:01 AM
Location..although this is a generic pic.
Shop Foreman
Corvette Specialist
L1 Certified
Old 06-15-2004, 08:01 AM
jlaw jlaw is offline
98 Chevy Blazer with same problem How do you fix it?
How Do you Fix it....
Old 06-15-2004, 05:42 PM
Re: 98 Chevy Blazer with same problem How do you fix it?
Took the Blazer to my chevy dealer and they replaced the speed sensor. It actually had a crack in it. I has been fine ever since.
See BOWTIEBANDIT's reply to my original question he was completely acurate. Good luck.
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
'95 Town car ABS light on and hesitation olopezm Town Car 5 12-02-2010 06:30 PM
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 07:51 AM
95 silverado abs light is on and smells like brakes joseriverasg Silverado 2 12-21-2009 10:15 AM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
