Old 02-15-2010, 01:20 PM
jeffs2002 jeffs2002 is offline
94 PA Check Engine Lights - Still
I have replaced my MAF sensor, ERG valve, air filter and O2 sensor and still my check engine light still comes on and once and a while my traction light come on. Any idea what I can do next?
Old 02-15-2010, 01:49 PM
maxwedge maxwedge is offline
A990 racer
Re: 94 PA Check Engine Lights - Still
Start by posting what codes are popping up, no?
Old 02-15-2010, 01:58 PM
I don't know what codes are coming up. The mecanic that has been working on it said different codes come up. They now say it could be a hrmonic balancer. I was just hoping someone else had these problems and had found an answer.
Old 02-15-2010, 03:44 PM
tempfixit tempfixit is offline
I would not let them do anymore until you get the codes and post them here. Replacing harmonic balancer makes me believe they are just throwing parts at it. What kind of runability coditions do you have??
Old 02-15-2010, 05:03 PM
The car drives fine, it's jus that light that just keeps popping up.
Old 02-15-2010, 11:39 PM
GO to autozone or any parts store that will read the codes for free. Get the actual code numbers and post and someone will help.
Old 02-17-2010, 10:54 AM
Jrs3800 Jrs3800 is offline
99% of the parts stores can't read a 1994-1995 GM C body....
Do you know anyone with a Scan Tool capeable of reading the Odd Ball 94-95 GM's? If you were close I'd read the codes for you...
Old 02-20-2010, 03:15 PM
I had it scanned at Aamco and they said it was a 1641 code, but that points towards a bad computer which I already had replaced.
Old 02-20-2010, 07:43 PM
There is no 1641 code for this PCM/EPROM
However, code 1640 is QDM( Quad Driver Module ) #1...
So what is happening is that the PCM is seeing a problem with an Item on quad Driver 1... You will have to figure out what the #1 Quad Driver controls and check those items..
Old 10-02-2010, 08:31 PM
Thom54 Thom54 is offline
Did you swap out the Eprom from the old computer to the new one?
Old 10-21-2010, 03:59 PM
I have no idea what the Eprom is.
Old 10-22-2010, 02:11 PM
kaspr kaspr is offline
That is the chip that goes onto the PCM (computer) that stores vehicle-specific information. You need to keep the one that was on your old computer by transferring it to the new computer. Or else you need to have your new PROM chip calibrated.
