Old 02-14-2010, 10:26 PM
92.H.A.ex 92.H.A.ex is offline
Unhappy i dont no wat to do
Can a bad valve couver gasket cause shaking?
(when in park,also sitting at a light?
checkengine light come when going-70-80 mph and comes on when car is seating at a light.....?
some times it dont come on...
when i changed alot of parts i never reset the ecu....fuse 7.5......and i never reset the memory...?
i didnt unplug the bettery can that be a reason? same code might be popin up causing the checkengine light to pop on...?
Old 02-14-2010, 10:53 PM
consultIII consultIII is offline
Re: i dont no wat to do
if your engine is shaking at idle you have a misfire. ecm misfire counter may set a dtc for the specific missing cylinder...check for dtc first. If not; isolate the misfire to a specific cylinder by doing a power balance test.
what type of car, year and engine?
Old 02-15-2010, 12:00 PM
it is a honda accord ex 2.2 auto trans....
Old 02-15-2010, 12:01 PM
1992
Old 02-16-2010, 10:41 AM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
a bad valve cover gasket will not cause shaking... maybe leak but these two symptoms are probably unrelated
