96 chev pu lacks power and surges
I have a 96 chev pu 2wd 4.3 v-6 5-speed.It starts and idles good.Sometimes runs good.Then you start driving it will surge and loose power and then it will start to run right and go on.I put on a new fuel filter didnt help.It probably needsa good tune-up but it seems to be starving for fuel when it runs bad.Could it be maf sensor or something like that? thanks phil
Re: 96 chev pu lacks power and surges
Yes, a MAF sensor is a possibility. At idle, tap the MAF with a screwdriver handle and if idle changes, the MAF is bad.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
had a bad map sensor on a 99 5.7 that acted like that. It did not set a code, but my freind (GM Mechanic) noticed low values... (out of range).
----------------- Elbert Clarke |
