Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-14-2010, 07:38 PM
napoleankjj2006 napoleankjj2006 is offline
1988 dodge d100 lost heat
i lost my heat after i drained some antifreeze to put in a bottle of head gasket fix. i put more antifreeze in after that to top it off. my heat worked before i did this. could it just the heater core is clogged up? i replaced the thermostat and gasket today. the hose going from the radiator to the engine is hot but my heat isnt.
Old 02-15-2010, 08:45 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 1988 dodge d100 lost heat
You might have air trapped in your cooling system. Park the truck with the passenger side front a foot or higher than the driver's side rear, start the engine and let it come to running temperatures with the radiator cap off. After you see coolant circulating through the radiator, rev the engine a little then top off the coolant level in the radiator.
This is called "burping" the cooling system.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 02-15-2010, 02:24 PM
would using a 2 ton jack and jacking up the passagner front tire as high as the jack go be high enough to burp it? if so i did that and it was full on antifreeze. if not can you tell me what is high enough that i can ride my passagner front tire on to get at least a foot high off the ground?
Old 02-16-2010, 07:48 AM
AF - Advisor
That shoulda done the job. Are both heater hoses hot?
Old 02-17-2010, 01:32 AM
they were warm. do they need to be hot or warm? if they should be at least warm then heat got warmer while im on the gas
Old 02-17-2010, 08:06 PM
AF - Advisor
After the engine warms up from driving around, the hoses should be hot.
Is there a temperature gauge on the instrument panel?
Old 02-18-2010, 09:08 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I've also had luck burping older Mopars by putting the front end about a foot higher than the rear, and running it with the radiator cap open.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-19-2010, 10:41 PM
i drove about 4 hours and the cab got warm but not hot. i did see the antifreeze was low so i topped it off.
