Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-13-2010, 09:43 PM
mattd424 mattd424 is offline
94 ram 1500 no power
hey everyone i have a 94 ram 1500 with a 5.2 it sat for couple years fuel system was flushed and fuel pump replaced.my truck starts geat and idles but stalls sumtimes.i can drive it fine but it takes a really long time to get up to speed rpm not coming up i can litterally park on loose gravel and stomp it and itll just ease off and slowly build rpm it has a little white smoke while running and skips a little.ide really appreciate any advice
Old 02-17-2010, 02:40 PM
Re: 94 ram 1500 no power
ok today i tested my coil with my fluke on ohm i get 1.7 ohm on plug in side and checking secondary from 1 plugin terminal and output post my meter doesnt register a thing.should my truck even run?
Old 02-17-2010, 08:13 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Sorry, the only trouble with ignition coils I can help with is if the engine won't start hot but starts fine cold.
After sitting a coupla years, it's likely the fuel injection is kinda gummed up.
I'd pour in a solvent cleaner like Gumout or Techron by whoever markets it now and just idle & drive the thing. Don't use the Lucas stuff....it has no solvents.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 02-19-2010, 04:15 PM
well over theese cpl days i drove a couple tanks with seafoam and yesterday took it to shop to have injectors cleaned.still no change bough new filter/regulator and installed it also
Old 02-19-2010, 08:52 PM
AF - Advisor
Was the fuel pressure ok?
Old 02-19-2010, 11:02 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Is there a possibility that the cat is plugged?
Old 02-21-2010, 01:22 PM
yeah there prolly is a possibility its pluged fuel pres is 36 not sure what it suppose to be
Old 02-21-2010, 06:19 PM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
supposed to be 45-55psi.
with the engine shut off 15-30 minutes do you still have pressure? (ie leakdown test)
exactly what injector service did you get? with it sitting 2 years i'd get the injectors rebuilt - check out Mr Injector on the web. If they serviced the injectors by just running cleaning fluid thru the fuel system then that's probably not going to cut it. Mr Injector will disassemble, clean, and rebuild the injector including replacing the internal filter inside each injector.
they charge $16 per injector. don't buy new unless they tell you one is bad. I'm about to do that myself with a car thats also been sitting 2 years
id address your fuel pressure problem first. might get adequate performance once thats fixed
Old 02-27-2010, 07:25 PM
Coastquick Coastquick is offline
All good info so far, but tap your cat converter with a rubber mallet or wood one. Listen for stuff bounching around.
Also pull your O2 sensor, see if that improves the drivability aspect.
