Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 10-27-2001, 02:42 PM
staholdn staholdn is offline
Question Fuel Pressure
I have installed a CAI, and JWT S3 cams. Do I still have the correct fuel pressure? Does the ECU correct for more air and adjust the pressure or do I need to instal a regulator? If so does the B & M Command flo fit the SR20 or do we need a different regulator (which one?). My air/fuel ratio gauge reads between lean and the top side of rich but never really rides in the rich side. I know this is o.k. but would I benefit from increasing the pressure or would this be a waste of time and money?
1993.5 G20
JWT S3 Cams
Weapon R CAI
Vortex Exhaust
Timing Advance 17*
Old 10-27-2001, 07:48 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
No it fine don't dick around with it you'll end up fscking something up. The stock ECU can compensate just fine.
Old 10-27-2001, 10:52 PM
P10DET's Avatar
P10DET P10DET is offline
Re: Fuel Pressure
Don't waste your money. Adjusting your fuel with pressure is the ghetto way to do it. The SR20 uses a hot wire MAF and will adjust for additional airflow, unlike the MAP system in Honduhs and some other cars.
Sorry to be the one to tell you this, but air/fuel gauges are a total waste of money. They are not sensitive enough for tuning and can even screw with the ECU reading the O2 sensor.
I agree with Jason all the way.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 10-28-2001, 09:20 AM
G-Forces's Avatar
Banned
Well, the air/fuel meters/sensors that are worth it are HELLA expensive! I was looking at getting a 5 wire air/fuel meter...$1000. Damn I don't need it that bad.
Old 10-29-2001, 04:11 PM
Caribbean NISMO Caribbean NISMO is offline
I installed an autometer pro-comp air fuel ratio guage and fuel pressure guage in my P11 this weekend .Whats that about the air/fuel ratio guage screwing with the cars ECU readings.
Old 10-29-2001, 04:21 PM
G-Forces's Avatar
Banned
Well if I remember correctly you need to tap into the stock O2 sensor to get the reading for the A/F meter right?
Apparently when you tap into the wiring harness with a wire you change the reading that the ecu sees...it changes slightly, enough that you probably won't notice a difference but you won't be running at peak performance. I would be better to leave the stock O2 sensors alone and buy another seperate sensor to measure a/f ratios. However the narrow band or 3 wire sensors are not very good for tuning and the 5 wire or wide band sensors are freaking expensive.
Reading high fuel pressure (carbureted) caffeineaholic Caprice 16 09-25-2010 02:55 PM
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 06:32 PM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 09:09 AM
fuel pump pressure specfications dieter LeSabre 7 07-29-2009 02:05 PM
97 Blazer low fuel pressure new pump stalls in gear ChevyFamily Problem Diagnosis 6 06-05-2009 06:12 PM
