Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-13-2010, 03:42 PM
vlusk07 vlusk07 is offline
Code P1390
I got a code P1390 and it explained it as the timing belt missing teeth. does this mean that the belt itself is missing teeth or that one of the gears is missing teeth and the timing belt isn't being able to hit it? thank you
Old 02-14-2010, 10:12 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Code P1390
The timing belt may have jumped timing. The timing belt has teeth on it and one of the cam gears could have slipped causing the timing to be off. You need to check out the timing to make sure and retime the motor if it is off.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-18-2010, 01:18 AM
Re: Code P1390
would that cause the motor to randomly cut out?
Old 02-18-2010, 09:03 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Code P1390
Skipped timing will cause the compression on the motor to lower since everything isn't in time with each other. One tooth is usually not enough, but multiple will cause it to totally die. But you're also looking at valve damage if it skipped more than one.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
