Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 02-13-2010, 01:17 PM
worm6 worm6 is offline
misfire #3
year 2000 and just had the head gaskets replace. I i had the heads sent out and checked over. After fix i had misfire #3. Now new plugs new wires new coil and new injector. Van still runs alittle rough and have misfire #3 show up after running van and stopping for awhile. Van runs down road great just when you stop it will stumble and miss. Any ideas because monday i will take it back in to shop. Also could a valve cause the sensor to read misfire?
Thanks i don't know what else to do.
Old 02-13-2010, 02:08 PM
danielsatur danielsatur is offline
Re: misfire #3
Do a compression test on cylinder 3.
Old 02-13-2010, 03:40 PM
Re: misfire #3
Okay i'll have shop do test. Can you explain what kind of result i might get from the compression test? Does it give you accurate infomation as to why you have a miss? Or does it let you know where to look next? The motor also is a Jasper remanufactured engine and has 55,000 miles 4 1/2 years so no warranty. And still headgasket went bad??? Jasper let me down. I'm going to take it on longer drive to see if it works it self out. Thanks
Old 02-13-2010, 08:20 PM
lesterl's Avatar
lesterl lesterl is offline
Re: misfire #3
The misfire could be caused by a bad valve, a cracked compression ring, fouled/ arcing plug, bad wire, bad coil, stuck open/closed injector, etc.
To test compression, you remove the plug from that cylinder, insert the guage, crank it over a few times, check reading, repeat test like 2x more. (this is done with the fuse for the injector harness unplugged) Repeat test for all cylinders and the lowest reading of the 6 cylinders should be within like 10% of the highest or something like that.
If you do have a weak cylinder, put a tablespoon full of oil in the plug hole and repeat the test for that cylinder, if compression increases you have bad rings, if not suspect head gasket or valve leakage.
Have you ran some seafoam through the top end?
I was getting a cylinder 6 misfire, I changed #6 plug for #2, installed a replacement wire, and found I had a bad ALT SENSE fuse (#30) in the underhood fusebox, it has never returned.....
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 02-13-2010, 10:00 PM
Re: misfire #3
Thanks for reply and on my longer drive i added seafoam to a full tank of gas. I went around a 100 miles and still have small shaking or stumble with no check engine light. The van runs perfect going down the road. Only while idling do i feel the shake. And at idle if i rev up alittle is smooths out. This only started after head gasket change. I know the shop will take another look but they seam to not be able to figure it out. Shop put new plugs and wires on for free but this didn't work. Today they put new injector in and still no luck. Wish me luck because we didn't talk about money on that and i have van without paying. I checked #30 fuse and was good. Tomorrow i think i'll clean maf and push on all air lines, who knows maybe that will help. Thanks again for reply and ideas.
Old 02-13-2010, 10:29 PM
lesterl's Avatar
Re: misfire #3
Mine was rough untill I seafomed thru a vac line and blew a BUNCH of carbon out, is much smoother, I also cleaned MAF, but not much change there (240k on the clock.)
Old 02-13-2010, 10:54 PM
Re: misfire #3
Do you rev up engine as you use seafoam or just let idle. Thanks
Old 02-14-2010, 01:24 PM
lesterl's Avatar
Re: misfire #3
Depends upon how fast you are feeding the seafoam in. The faster you feed it in, the faster you need to have the engine run so as to not hydrolock the motor. Most people will put 1/2 in the tank, fill the tank. Hold the other 1/2 near a manifold vacume source (I put a piece of hose over the vac supply for the transmission vac modulator, being yours is a 2000 you may not have the vac modulator, but the port will be very near the air filter side of the manifold with a rubber cap if no vac modulator. Use the rubber hose to pull the seafoam in slowly at idle and a little faster when revved, it is BEST to do this with the engine warmed up. The last little bit of seafoam should be used to stall the engine, let it sit for 10 min or so, then the fun of trying to restart it begins, you will have lots of pretty white smoke as the carbon burns off and I did mine in the snow, I had lots of black debris in the snow under the tailpipe, I also had some white smoke comming from under the van behind the engine (found an exhaust leak near the manifold- actually the doughnut from manifold to the pipe is bad, might explain the low mileage!!!!) Good luck!
Old 02-14-2010, 07:41 PM
Re: misfire #3
I ran out of time today. Brakes on my car needed attention. So i will want to let the vacuum line pull the seafoam out, not pour it in? No check engine light today so maybe it's getting better. I read the bottle and it says you can put in the oil or the gas. Would putting some in oil help anything? And do you just leave in oil intill you change it?
Thanks again, if i firgure this out i'll let you know.
Old 02-14-2010, 07:47 PM
lesterl's Avatar
Re: misfire #3
I dont recommend doing it in the oil, it could wash the oil off your cylinder walls or out of the bearings, that could be bad, Not to say it hasnt been done without ill effect (I have done it once, but it didnt help). Changing the oil regularly and with good quality oil will help clean it up. I use it regularly in gas and in the intake with no permanant damage (sometimes you can foul up plugs or plug an EGR with carbon).
Old 02-15-2010, 09:35 PM
Re: misfire #3
I took in today and he sprayed maf sensor with cleaner and not much changed. He spent about 1 1/2 hours hooked up to computer driving and checking and couldn't find anything out of range. So i took him with me for about six blocks ran great, then stopped and started chugging alittle. I don't think he belived me about not running correctly. Now after me and him in van he knows what i'm talking about. I'm dropping off tomorrow for a strut bearing repair and i'll let him keep for a few hours to see what he finds now that he know what the shake i feel is.
Old 02-16-2010, 06:15 PM
534BC 534BC is offline
Re: misfire #3
My best guess for this is a leaking intake valve.
Old 02-16-2010, 07:56 PM
Re: misfire #3
I got the strut fixed and thats the good news. I may be loosing coolant again. MY wife had the heater get cool and the temp gauage started jumping around. When the garage looked it was low on coolant. After looking at engine no sign of leaking anywhere. So he thinks it was maybe a air bubble. I don't i wish the engine would blow or something so i can tell him to fix it. Or he can pay me off and i'll go away and not fix this junking van ever again. I'm starting to look around at the ford dealers and see what i like. Let you know how the van ends up.
Old 02-17-2010, 04:31 PM
Re: misfire #3
If it using a tiny bit of coolant then my next best guess is leaking head/head gasket.
Old 02-17-2010, 07:26 PM
Re: misfire #3
That would be bad because just had that done. Had heads over and shop and checked and cleaned and sanded or planed or ground or grind the bottom to make flat. Whatever they called it. Also paid to have new lifters and pushrods and new headbolts put in.
Okay pressure test today and no problems. Put on new radiator cap lets see how it goes. Also my misfire three has gone away but still have a miss or shake to motor. I was told by a few other people that i should just drive it intill the problem becomes more clear. Otherwise i can start changing those sensors and hope i find the bad one first not last. So far i've gotten free plugs and wires and thermostat and injector and mass airlow cleaned. But i did pay $5 dollars for the cap today. I'll call that even
