Old 02-13-2010, 01:50 PM
okyoki okyoki is offline
88 civic sedan motor mounts
how many are there? where is the transmission mount on an automatic 1.5 motor? where are the mounts located? how do I replace them?
Old 02-15-2010, 12:57 PM
DownToGround DownToGround is offline
Re: 88 civic sedan motor mounts
there are four mounts on a 88-91 civic front lower, rear middle, 2 sides.. the motor wont fall out if you replace 1 at a time, or even 2, probably even 3.
choose wisely.... u can do it
whats my lap time
Old 02-23-2010, 10:21 PM
big tex84's Avatar
big tex84 big tex84 is offline
yea it wont fall out, when i had my d, i broke the trans mount, front mount and rear mount, i drove an hour home with a ratchet stap holding it in youll be ok, very simple
Finally getting my swap done, Thought I would be relieved and satisfied, now I just wanna spend money on other car parts, WHERE DOES THE MADNESS END!!!!
Old 02-28-2010, 12:00 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Ineptly called "motor mounts", only one of them is actually attached to the engine.
That would be driver's side, right in front of the strut tower.
The other three locate the transmission, and they are:
Pass front, bolted to front cross-member
Pass rear, bolted to rear cross-member
Pass side, bolted to pass frame rail area, just fore of strut tower.
The front trans mount is difficult to get out if you can't move the trans into a slightly crooked position, so loosen all 4 mounts (do not remove, loosen) to give yourself some "wiggle room".
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
