Converter lock-up function, (4L60)
1983 GMC Vandura, 3/4 ton (G-20) with a 305/auto.(THM 700R4) 80,000 original miles
I bought this van at about 65,000 miles, and the TC lock-up did not work, but other wise the trans worked well for 10k miles. Then an annulus (ring) gear broke. I replaced the trans with a recently-rebuilt used 1991 4L60, which had the identical 3-wire wiring harness. The TC lock-up does not work on the new trans, either. So I am assuming the lock-up controller does not work. This van is Canadian, and uses a coolant temp switch and a vacuum switch wired in series to control the lock up. It looks like the vacuum switch is seized. So, I would like to temporarily hook up a manual TC lock-up switch. Can I just apply 12 volts to the appropriate wire going into the transmission to get it to lock up? If so, which wire is it? The green one? Thank you. |
Re: Converter lock-up function, (4L60)
Wire on pin A from TCC brake switch to transmission plug should feed 12 volts to the wire a circuit with brake switch close. Inside transmission wire a goes threw the 3-4 pulse switch and on threw lockup solenoid. From lockup solenoid the ground side is pin wire D that runs back to pcm. The vacuum switch I would just jump it. I do not have the wiring circuit on vacuum switch. Not sure tcc even runs threw it. If you can find a older transmission hand book it should have the TCC wiring and vacume switch wiring diagram in it.
You can replace the vacuum switch with a manual switch, but understand that the vacuum switch is intended to sense engine load and drop the TCC under moderate and heavier loads.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
